my time slips i need to know ,why so slow??
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
hello all, i finally got to run the baddass IROC and found it to be less than bad
I know my react needs work , and the 60' were lousy hook-ups. I am car 290, the temp was 75, dunno 'bout alt. I was told to get drag tires and sub frame connectors next. The gears are 2.77, the motor is a L98 has full exhaust and plugs/wires and the free stuff exc. plenum porting. 700r4 tranny
JUST ANOTHER DUDE TRYIN' TO GO FAST
'89 SHAGGY IROC
so much to do , so little money
[This message has been edited by irocnroll89 (edited July 25, 2000).]
I know my react needs work , and the 60' were lousy hook-ups. I am car 290, the temp was 75, dunno 'bout alt. I was told to get drag tires and sub frame connectors next. The gears are 2.77, the motor is a L98 has full exhaust and plugs/wires and the free stuff exc. plenum porting. 700r4 trannyJUST ANOTHER DUDE TRYIN' TO GO FAST
'89 SHAGGY IROC
i can' get hem on the page , they are on the net though
'89 SHAGGY IROC
'89 SHAGGY IROC
You'll get more replies when you post your times!
SHOW ME THE TIMES!
89 IROC 350 Auto
Air Foil
TPIS Underdrive pulleys
K&N Air Filters & Mods
Modified MAF and screens removed
Ported Plenum
Edelbrock TES Headers
TRUE DUAL Exhaust
Edelbrock Performer Aluminum Heads
ZZ9 Cam
TPIS Level 5 Chip
2200 Stall Converter
2.77 Rear Gears(gotta get 3.73)
SHOW ME THE TIMES!
89 IROC 350 Auto
Air Foil
Ported Plenum
TRUE DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
Well type them on a reply.
89 IROC 350 Auto
Air Foil
Ported Plenum
TRUE DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
89 IROC 350 Auto
Air Foil
Ported Plenum
TRUE DUAL Exhaust
ZZ9 Cam
TPIS Level 5 Chip
ok best time of 15.073 at 92.93mph, with r/t of .863 and 60 ft of 2.302
best r/t was .647w/ 2.227 60 ft. at 93.92 mph
these are my first 4 runs ever!! they all were 15.073-15.297 with low a mph of 91.59 and high of 93.92 sorry 'bout the faux paux
'89 SHAGGY IROC
'89 SHAGGY IROC
Don't worry about your reaction times. The clock doesn't start till you leave the line. Work on your 60'. With that mph and a 2.00 60' you could get 14.5's. After you stage put your left foot on the brake and bring the rpm's up to 2000. When you see the second yellow go out take your left foot off of the brake and floor it. If it spins try it at 1800.
Good luck and have fun
3700lb 86 Z-28. 14.52 @ 93.13mph. 305 TPI
Car: Mullitt mobile :)
Engine: it's stock LOL
Transmission: 700rJunk
Axle/Gears: 2 much 4 street not enough for strip
The first few times I ran my car ('89 Iroc L98, 2.77 geared) I could only get 15.0s @90mph. My transmission was slipping bad on the 2/3 shift. A friend of mine, told me to start shifting the car instead of letting it do it. My next pass went to 14.8s (still with a bum tranny, on that run I had to shift in OD then back down to 3rd to get the car to shift.)
Like it was said before, with your trap speeds you should hit mid 14s. I hit 14.3s at 94-95 mph.
Sparks a flyin'.
Sparks a flyin'.
Sounds like you need gears in a bad way. Are you spinning alot at takeoff?
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Car: 2006 Silverado 1500
Engine: 5.3L
from what i can see, your main problem is the 60' times. drag tires shouldn't be needed for a car running them times. just work on your launch. try adjusting tire pressures, different ways of launching, etc. with the 2.77 gears it shouldn't be that hard to come out of the hole without spinning.
My corrected times for sea level were 14.5 @ 96 mph (last time I ran, before I installed the PR chip), and I have a 2.77:1 rear end, headers, cat back, free stuff, great tires, and thats it, so your times are not that far off.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
L98 TPI 350 (5.7L)
thnx to all i am glad to see that even with the 2.77 i can have a decent time....
'89 SHAGGY IROC
'89 SHAGGY IROC
Street Lethal
Apr 30, 2019 12:14 PM
maroe624
Apr 16, 2017 08:29 AM
