Weird idle problem
Old Apr 27, 2003 | 02:52 PM
camaro87's Avatar
Car: 1987 IROC-Z/28
Engine: 305 cid V8
Weird idle problem
Hello,
My IROC Z/28 is exhibiting some weird idle behavior lately. During warm up, it seems to idle fine. However, after that it might not idle around 500 rpm where it should when stopped and in drive. Sometimes it idles around 1000 rpm, and I'm pretty sure I've seen 1,500 one time. About half the time it does this weird idle stuff, and the other half it idles fine, around 500 rpm.
When I try shifting to neutral, it idles even higher, around 1500 rpm. Wondering if anyone has any experience or ideas about what could be causing this problem and how to fix it?
I've got a 1987 305 auto.
Thanks,
Tristan
Old Apr 27, 2003 | 02:55 PM
waltersb's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 305 TPI (LB9)
Transmission: Auto 4
Did you do a search on the boards with 'idle problems' ?
there's lots of ideas about what the problem is, just need to do a little reading....
Old Apr 28, 2003 | 07:36 AM
Vader's Avatar
Is that '87 a carb or TPI?
Old Apr 28, 2003 | 08:53 AM
camaro87's Avatar
Car: 1987 IROC-Z/28
Engine: 305 cid V8
Ahh yes, knew I forgot something!
It's a TPI IROC.
Tristan
Old Apr 28, 2003 | 01:24 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I have had major problems with idle issues on my car. I have done alot of work on my car to correct this.
Infact check the TPI board right now. There is someone on there with similar problems. You can probably find your answer there.
Old Apr 28, 2003 | 08:10 PM
Vader's Avatar
Check for throttle plate binding, throttle cable wear/binding, clean the throttle body, IAC, and IAC air passages.
Old Apr 29, 2003 | 01:10 AM
jocww's Avatar
Car: 84z, 65 elcamino
Engine: l69 and a hyped up sbc in the camino
Transmission: t5 m21
Axle/Gears: 373s 411s
i have that same prob with a carb tho i would like some help to thanks if possible
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Cleotiz
Jan 6, 2018 08:56 PM
CORV3TT3
Aug 23, 2015 11:26 AM
