PINION ANGLE SETTING...need help. is this correct? pics of indictaor within...
Old Apr 27, 2003 | 07:34 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i also posted this in the tranny/drivetrain section, but thought i would get more exposure here...so, sorry if you saw it twice.
ok, for some reason, i am having a heck of a problem understanding exactly how to set the pinion angle on my spohn TA.
the directions say to subtract the reading of the pinion from the reading of the driveshaft, and that is the pinion angle, for which i am looking to get -1 degree.
here are two pics of the indicator, taken from the passenger's side of the car...
and...
now, if i am reading the directions correctly, i take the driveshaft angle which is 2.5*, and subtract from it the "pinion" angle, which is 3.5*. that gives me -1*.
is that correct? or are the readings taken relative to something else? if you have any light to shed on this, PLEASE help. i have done a couple searches, and havent gotten any concrete answers. thanks...
-brian
Old Apr 27, 2003 | 09:52 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Here is what I did. I took the driveshaft out and set the base of the angle finder on the yoke. Set it to -4 degrees. The day that I set it to that I got 1.64 60' times consistently on MT et drags. That was compared to 1.8's before with the stock torque arm.
87iroctheo
Dec 4, 2016 11:47 AM
aaron7
Aug 17, 2016 06:02 PM
lt1z350
Sep 29, 2015 01:50 PM
89fast5oh
Aug 24, 2015 08:14 AM
Linson
Aug 21, 2015 02:12 PM
