Anyone ever experience a bad valve lifter?
Old Apr 28, 2003 | 02:52 PM
ULTM8Z's Avatar
I still have somewhat of a mis-fire phenomenon occuring at idle speeds that disappears above 1500 rpm. Having already replaced every ignition component on the car and gone through the entire fuel system, I'm inclined to think it's a mechanical problem.
The engine has passed compression and leak down tests and there is no blue smoke coming out of the exhaust, so I'm also inclined to believe the bottom end is ok as well as the valveseats and valves.
The only other thing I can think of that would cause something like this would be a faulty lifter
Any thoughts?
Old Apr 28, 2003 | 03:44 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No
vacuum leak
Old Apr 28, 2003 | 08:30 PM
Damon's Avatar
Doubt it. You'd have a nasty valve tap if the lifter was collapsing.
gta90
Sep 15, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
Bubbajones_ya
Aug 28, 2015 02:17 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
