car idles loe with a/c on?
Old Apr 29, 2003 | 09:24 AM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
okay i have an 89 camaro i when i turn the a/c on it idles low and rough but when i shut it off the car idles perfect what can it be i have the 5.0 tbi motor help me out
Old Apr 29, 2003 | 11:18 AM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
I had the same problem out of my car. It didn't go away until my ECU got replaced. I am not saying that is what you need to do. Have you checked your AC belt? Or are you running serpentine? I would also check your hoses and what not.
I am not really sure how the problem got fixed in my car. I replaced a bunch of hoses and belts, then my ECU got replaced for a different problem. Then my AC worked just fine.
Old Apr 30, 2003 | 07:14 AM
blue86iroc's Avatar
Car: 1986 IROC-Z
Mine used to do that too. The reason why you're dropping RPM is probably because the car isn't compensating for the extra load on the engine. A lot of cars will increase the idle speed slightly when the A/C is switched on. I don't have this problem anymore (pulled the A/C ).
Old Apr 30, 2003 | 07:18 AM
90formula5.7's Avatar
re
idle air control valve is probably fualty or dirty try cleanind it first!!
Old Apr 30, 2003 | 08:28 AM
Car: 89 Camaro RS
Engine: 5.0 tbi
were is that idle air control and what does it look like?
specialized
Jun 18, 2022 09:26 AM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Wade787b
Sep 29, 2015 01:15 PM
