Problem please help
Old Apr 29, 2003 | 09:51 PM
Iroc88z28's Avatar
Problem please help
ok.... I reset timing, and I can get car to idle perfect.... I go to put it in gear and it will stumble and backfire with the littlest of gas I give it, or it will just die. Funny thing is that I can drive the car if I leave the wire dissconnected, the one you are supposed to disconnect when seting timing (tan wire/black strip, by heater box), it will run, doesn't seem to have all its power but I can atleast drive it, but it heats up quickly and I saw exhaust manifolds were glowing red, at night, under no light.
What could be the problem, controller mod, EST, vack leak, egr. I do have a vavle cover gasket that I found to be split, could that cause a vac leak?
I have a '88 IROC Z-28, 5.7L, TPI, L98 bone stock except for MSD 6a...
Possibly soon for sale...
Thanks in advance
adam
Old Apr 29, 2003 | 10:09 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
what did you set your base timing to?
and did you remove your ESC connector when you set your base timing?
Old Apr 29, 2003 | 10:28 PM
Iroc88z28's Avatar
At first I left it just as it was at zero then played around a little with it, turned dist, then I remember to disconnect the wire. I probably went wrong there, and screwed myself, needed to disconnect ESC wire before playin with dist. But I did go back and reset it with the ESC wire disconnected. Its advanced just a little. I would say no more than 8*..
Would it just be better that I reset timing completely again. Since I know how to do it. but then ok when I reset it, I disconnect the ESC wire fist and set the timing where. at 0* or do I leave it disconnected and start it up, and then set the timing, couldn't I just leave it at 0*?
Please and Thanks
adam
Old Apr 30, 2003 | 05:39 AM
your doing this with a timing light correct?
Old Apr 30, 2003 | 07:09 AM
Iroc88z28's Avatar
Yep.. I don't know what is up with it, maybe I am doing nothing right, but at least it will run somewhat so I am making alittle more progress.
adam
pjsparts
Oct 29, 2025 06:39 PM
88rscamar0
Sep 23, 2015 09:08 PM
Ranbo108
Sep 9, 2015 12:20 PM
383cam
Sep 9, 2015 06:01 AM
andy74
Sep 3, 2015 08:41 AM
