Rusty Cam
Old Apr 30, 2003 | 02:14 PM
TonyC's Avatar
Car: A Camaro
Engine: Weak
Transmission: Weaker
Rusty Cam
I bought an LT1 cam from some dude and unfortunately there's some rust on the cam. I'm talking about on the cam lobes and the bearing surfaces. Should I take it to a machine shop? Use some sand paper? Just toss the cam in?
Old Apr 30, 2003 | 02:32 PM
ede's Avatar
ede
if it's bad enough to need sand paper trash it, brass wire brush on a bench grinder works good for rust removal or scotch brite
Old Apr 30, 2003 | 03:12 PM
JesasaurusRex's Avatar
Id say its time 4 a refund
Old Apr 30, 2003 | 03:15 PM
Vader's Avatar
As usual, Ed is probably right. If it were a flat tappet cam, you could likely get away with sanding the lobes, but a roller lobe AND the journals are a little more sensitive to surface finish. If you need much more than an oily ScotchBrite to clean them up, they probably shouldn't be used. If there is only some staining and discoloration after the cleaning with a ScotchBrite (and no pitting) you should be safe.
Try the brown (more coarse) ScothchBrites rather than the green ones.
Got a photo?
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
