Engine Rotates but doesnt Start.
Old Apr 30, 2003 | 04:25 PM
Drunken_Polak's Avatar
1st of all I have searched...which gave me a few more things to check but i havent found the problem yet.
Basically This morning i got in the car to go write my exam at school...and it wouldnt start .
It cranks but doesnt actually start... if i give it a bit of gas (accelerate) it starts up...but if it drops down to 2000-1500 rpm it dies... heres what ive checked:
1. if i have enough fuel (i went to gas station and got a galon)
2. checked battery...and battery terminals
3. wiring seems to be ok...
Background info about my car:
Iroc-z '85, 350 TPI
I just put a new ECM in there...so im thinking that might be the problem as well... I dunno how to reprogram it....in fact im just learning about cars in general...
Thanks in advance
Old Apr 30, 2003 | 06:44 PM
ede's Avatar
ede
i'd check fuel pump, make sure it's running, check preasure
Old Apr 30, 2003 | 07:48 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
like ed suggested a good place to start would be a fuel pressure test.. do a search on testing fuel pressure im sure you will find quite a few threads dealing with testing pressure on a tpi system.. its may just be something as simple as a clogged fuel filter or a carboned up iac motor.. is it throwing any codes?
Old Apr 30, 2003 | 10:10 PM
FOUND IT!
Dang... I feel stupid... I spend 5+ hours troubleshooting...
my dad comes home...10 minutes he finds its the Idle setting screw thats too loose....so we tightened it (giving the engine more air) and it works now My engine still is a little weird rotations....they seem unsteady... any ideas for that?
theshackle
Mar 5, 2017 06:37 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
djmarch
Aug 19, 2015 12:07 PM
Bryan F
Aug 18, 2015 02:28 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
