Will my 92 TPI throttle body work with a Mini-Ram? Thanks,n/m
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Yes you can use an 89-92 T.B. on a MINI-RAM, as long as you use the TPIS supplied piece of ALUMINUM that mounts to the LEFTSIDE FUEL-RAIL front bolt. This will allow the 89-92 throttle cable and T.B to work PROPERLY withthe MR. Call TPIS and have them send you one if they didn't supply it with your MR. HTH's
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Terrell351
Jun 13, 2021 01:13 PM
