factory piston cc's?
Old May 2, 2003 | 01:04 PM
badgta's Avatar
Car: 1991 FORMULA
Engine: ZZ4 + LT4 HT CAM 430HP
Transmission: 700-R4 COMING T56
Axle/Gears: 9" 4.56's (COMING)
i'm trying to calculate the compression on the factory l98 shortblock i will be ordering soon..
it will have afr 190's with the 68cc chambers and a felpro 1003 head gasket... the gasket has a 4.166 bore and a .041 compressed thickness......
i figured a ballpark estimate would be around 9.0:1 but i would like to know what it will be exactly.....
Old May 2, 2003 | 01:09 PM
ede's Avatar
ede
how you going to know how far in the hole you are? guess? as a rule pistons with 4 valve notches will run around 4cc
Old May 2, 2003 | 01:16 PM
badgta's Avatar
Car: 1991 FORMULA
hmm
well most factory 350's will be down the bore about .025... it varies..... i'm trying to get those most accurate calculation i can.....
Old May 2, 2003 | 02:43 PM
Vader's Avatar
I've measured from just under 4ml (maybe all the carbon wasn't cleaned out) to just under 6ml on some "factory" 4-relief pistons. Deck height is another factor, as well as top ring depth if you really want to split hairs.
Old May 2, 2003 | 03:43 PM
f-crazy's Avatar
Car: Bright Red 91 GTA
Engine: CARBED LT4
Transmission: MK6
lmao@ your sig vader
Old May 2, 2003 | 04:13 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Heres some numbers.
Bore = 4.00"
Stroke = 3.48"
Deck = .025"
Head cc's = 68
Valve reliefs = 3.4 cc's
Head gasket dia. = 4.166"
Head gasket thickness = .041"
C/R = 9.36 to 1
Auggie
Old May 3, 2003 | 12:01 PM
badgta's Avatar
Car: 1991 FORMULA
hmmm
i don't see how it have 9.3:1 when thats what the factory l98 long block is rated at with 64cc heads...... maybe the head gaskets is thin enough to take up the difference?
Old May 3, 2003 | 01:03 PM
Auggie's Avatar
Boy, I don't know but if the L98 eng. with 64cc heads and a .060" head gasket that eng. would have a C/R of 9.34 to 1
Auggie
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
GTAman
Sep 26, 2015 02:01 PM
BBSDesigns
Sep 22, 2015 03:08 PM
gta892000
Sep 16, 2015 12:40 AM
gta892000
Sep 16, 2015 12:37 AM
