Put trans/engine in?
Old May 2, 2003 | 01:55 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Transmission: Probuilt 700R-4
I know on some vehicles you can do this but I have a 1991 Z-28. Do you guys think you can put the engine in with the trans installed on the back of it? Obviously I would have most of the stuff off the engine. Thanks.
Old May 2, 2003 | 02:54 PM
Vader's Avatar
With the pipes, linkages, wiring, and crossmember out of the way, AND the hood off, distributor out, and vehicle raised, you should be able to install it from the front, already assembled. If you are using a manual trans, it could be tricky getting teh seal and shifter to line up with the floor opening, however.
Old May 2, 2003 | 05:09 PM
PaveTim's Avatar
Car: 1991 Z-28
Engine: 350 SBC
Yeah all that stuff will be off. It is an automatic, so i'll try it when I am ready. Thanks.
Old May 2, 2003 | 06:03 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Comes out that way, so should go in that way.
Old May 2, 2003 | 07:43 PM
1986redbird's Avatar
I just put my engine/tranny back in my TA hooked together, of course I have everything out of the engine bay. I found it best to jack the rear of the car up that way the tranny can slide under it without tilting it too far. I installed it by myself with no problems, definatly pull the dist out of the motor first.
Old May 3, 2003 | 10:48 AM
Beefy89's Avatar
Thats the way I did it.............
Old May 3, 2003 | 01:11 PM
Vader's Avatar
Beefy,
I friggin' LOVE that signature, dude! LMAO
That guy's gotta be the Iraqi equivalent of Geraldo - the only source of laughter for the poor Iraqi people in the last couple of months.
Old May 3, 2003 | 01:41 PM
Riley's35089rs+'s Avatar
Car: 89rs (previous 2.8)
Engine: 406
Transmission: 700r4 (for now)
Love that sig..he reminds me of our last president .."I never had sexual relations with Monica" LMAO!!!
Jake_92RS
Jan 28, 2020 10:37 PM
dyeager535
Aug 28, 2015 08:10 AM
michealleger
Aug 26, 2015 03:29 PM
87 camaro iroc
Aug 20, 2015 07:47 AM
Fronzizzle
Aug 9, 2015 01:15 PM
