Thermal Barrier Coating of a TPI Intake
Old Jul 26, 2000 | 06:46 PM
Ponchojoe's Avatar
Has anyone tried a thermal barrier coating on a TPI intake? Wouldn't it make for a cooler intake? I'm thinking of Jet Hot coating the bottom with a thermal barrier coating to aid in the performance of my new Edelbrock TPI intake.
Old Jul 27, 2000 | 08:26 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I say go for it. Ceramic coat EVERYTHING!! At the least it helps perserve the finish.
James
Old Jul 27, 2000 | 08:27 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
oops double post.
James
[This message has been edited by scooter (edited July 27, 2000).]
Old Jul 27, 2000 | 05:57 PM
D_Amlee's Avatar
Car: 89 IROC
Engine: Yes
Transmission: That, too.
Coating the bottom portion of the intake base would keep the hot oil from warming up the aluminum intake nearly as fast. But, the upper portion of the TPI system is in contact with air in the engine bay, and I don't believe that jet hot coating would help you there. Better might be a thin black coating which would generate more heat loss through radiation.
Old Jul 27, 2000 | 11:07 PM
3.1 firebird's Avatar
do the combustion chambers.
Old Jul 28, 2000 | 05:45 PM
freeze92's Avatar
Call Endura Coatings in Mesquite, Texas (972)288-3570. They coated my headers for my truck, and did an excellent job, a lot cheaper than HPC. They can also do a couple of different colors.
1992rs/ss
Jan 31, 2025 05:10 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
theurge
Aug 21, 2015 12:46 PM
Sanjay
Aug 12, 2015 03:41 PM
