distributor question
Old May 2, 2003 | 08:10 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Engine: 383cid, 350cid
Transmission: 4L60, NV3500
Axle/Gears: 3.73, 4.10
Will a computer controlled distributor fit and work correctly in an older engine that had a non computer controlled distributor?
Old May 2, 2003 | 08:21 PM
ede's Avatar
ede
fit yes work no
Old May 2, 2003 | 08:25 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Is there a way to make it work?
Old May 2, 2003 | 09:31 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Use a computer
Old May 2, 2003 | 09:43 PM
MTchevy1's Avatar
Car: 94 s10, 97 s10
Sorry guys, I worded that question poorly. I have an 89 RS, the motor is very tired. I have a fresh older 305 that does not have a computer controlled distributor. Can I put a computer controlled distributor in this older engine to use in my RS? I will be keeping the computer and everything, just a motor swap
Old May 2, 2003 | 09:51 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes, that will work just fine. Drop in. Depending on what motor it is you may have other issues though (intake bolts, flywheel / flex plate bolt pattern, oil dipstick)
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
