Need help NOW..intake swap..
Old May 3, 2003 | 09:43 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
I've got the carb and distributor off the old intake and realized the hole on the new intake for the distributor is a fair bit bigger.??Is this for a different size of HEI or something?My distributor is a non-comp HEI that fit perfectly in the aluminum 305 stock manifold thats on there now.I've never heard of there being different diameter hei's,but I have seen different lengths though.The new manifold is a Weiand #8004 which is widely used,will this work with my HEI,or am i screwed?I've got to know so i can get my car back together.
Old May 3, 2003 | 09:52 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Most aftermarket intakes, the hole has alot of tolerance to allow for misalignment... as long as your dsit will go in, and the gasket fits against it, it will be fine
Old May 3, 2003 | 10:50 AM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Thanks RB,It makes me crazy to take apart a perfectly good running motor to do stuff like this,i won't feel good about it until i hear her running again.I got thinking about it and realized it would probably be alright but i'm very appreciative for your quick response.Now i can continue the operation with one less thing to worry about.
Old May 3, 2003 | 12:58 PM
Vader's Avatar
If I am correct, there were also a couple of different "stalk" diameters over the years, not to mention aftermarket roller bearing distributors.
2QUIK4U
Jul 16, 2015 02:18 PM
marcus88
Feb 3, 2015 07:27 AM
xdamxincx
May 28, 2006 01:18 AM
Thirim
Mar 18, 2005 06:49 PM
