Modifying 92 Camaro RS convertible
Old Jul 28, 2000 | 02:37 PM
92RSd-top's Avatar
What type of modifications should i do to the above mentioned car. The car is a 305 tpi or 305 tbi not sure dont have the car yet need to find 98 and up vette for uncle.so right now im figuring out what i can do to the car.Id like to modify the heads, headers, exhaust, stereo, and anything else to the motor.
Your help is appreciated.
Old Jul 28, 2000 | 03:23 PM
p_racer's Avatar
If you are going to add a lot of power to a convertible, you have to stiffen it up to avoid bending the frame with the increased torque.
Old Jul 28, 2000 | 04:59 PM
Rob P's Avatar
Car: 89RSconvtZZ4TPI
Engine: ZZ4TPI
Transmission: 700R4 TRIPP TRANNY
If you have an RS you have 305TBI
If you have a Z28 you have a 305TPI. You need to make serious power to worry about the convertible frame. Figure out what you have, then come back.
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
71Impala convt 402BB
BETTER DRIVING THRU SUPERIOR HORSEPOWER!
Old Jul 28, 2000 | 05:06 PM
Drew's Avatar
A few things, first add subframe connectors... second, save your money.
Seriously an RS convertible is not the car to modify for performance. For what you'd spend you'd be further ahead to save your money and get a 91-92 l98 or lb9 Z or Formula hardtop.
The convertible platform wasn't designed to handle anymore performance than a 305tpi. Add into that the extra weight of the convertible, and the shortcomings of the 305tbi equipment, and it makes for a difficult project.
If after reading everything I've typed up to this point, you still want to mod it, here are the big ones.
Get a different aircleaner, L69 or open element. Get a good set of headers. a 3" high flow cat, and a good 3" catback.
From there you'll be at about the limits of TBI. Most people don't agree with me, but in most cases they're biased. Make your own call. You could do heads, cam, and intake, but the TBI won't really support it very well.
Drew
predatorman@hotmail.com
My Website
87 Iroc
91 Formula 14.3 @ 98mph
91 RS Convertible
92 S10
Old Jul 28, 2000 | 10:13 PM
fredo92's Avatar
Car: 92 Camaro RS
Hey man, I love the fact that you want to modify a '92 RS convertible. I have done about all i can with the 305tbi motor and I have decided it is a piece of crap motor. I am currently ripping out the 305/700r4 setup and I'm putting in an LT1/6spd setup. I just finished subframe connectors and I believe the frame is strong enough to handle the increase in horsepower and torque. If not, I'm putting a rollbar in it. Anyway, it's still a thirdgen, and it's a good looking thirdgen at that. Oh, and for the weight difference between it and a coupe, it's minimal and with real horsepower, it won't matter. Good luck with the car.
'92 RS convertible with 305/700r4, slp headers, 3" high flow cat, 3" flowmaster w/2.5" outlets/hypertech chip, k&n open element, "modified" eibach springs, kyb shocks&struts, and polygraphite bushings.
Old Jul 29, 2000 | 07:36 AM
Rob P's Avatar
Engine: ZZ4TPI
I modified my 89 RS over the course of several years. ZZ4TPI, Edlebrock Hi-Flow intake, SLP runners, 24lb injectors, MSD6AL, SLP dual cold air intake (battery in the trunk), Mini Starter, IROC front sway and wonder bar, steering box and rag joint. WS6TA rear sway bar, Z28 rear springs, Herb Adams adj Panhard rod, SLP LCA, Alston SFC, Aluminum Drive shaft, 3:23 posi disc rear, 2040 Stall behind my stock 700R4. My interior has the t/a door cup holders, 300ZX seats, Saturn/Delco CD player (it fits perfect!) 145mph/5500redline speedo/tach. All this in a hard top would be a blast, now think about doing this with the top down, smoking some jackazzz in a 5.0GT! The only thing different I would have done is start with a Z28 or IROC convt for the better suspension stuff. Press on!
Rob P
89RSconvtZZ4TPI
92Z28convt5spd
Old Sep 29, 2002 | 07:09 AM
Deemax's Avatar
Car: '89 RS Convertible
Engine: 355
Drew...
You might be right if all he wants is straight out performance...but a 'vert has an appeal all it's own, and there's plenty you can do to make them more than respectable performers. Not to knock anyone else's car here...or take away from anything..but I wouldn't drive anything but a 'vert. And mine runs just fine, making 300Hp on the TBI. It might be the upper limits of where I can take it...but 300 HP is still respectable power. And dropping that top on a warm summer night more than makes up for any extra weight I might be lugging around. Just my opinion...and of course, like you said...I"m biased
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
jklein337
Sep 19, 2018 06:23 PM
Linson
Aug 21, 2015 02:12 PM
