TPI intake manifold question
Old Jul 28, 2000 | 11:23 PM
innocence faded's Avatar
On the bottom of the intake there are 4 large cap screws. They appear to be in a coolant passage of some sort. What are they for?
Also, on the botttom of the throttlebody, that is the IAC correct? When I removed this for cleaning purposes it appears that coolant runs through a passageway and has caused the spring on the IAC to rust quite a bit. Is this supposed to be set up like this?
Jay
My Car web site
1987 IROC - 5.7 16.43 @ 82 mph ( yeah that bites )
1986 S10 pickup w/1993 Vortec 4.3
Old Jul 29, 2000 | 12:38 AM
Guest
Guest
Posts: n/a
No coolant should be where the IAC is, thats in a separate area.
The 4 plugs on the bottom are for the EGR passages.
Old Jul 29, 2000 | 08:02 AM
Maybe a gasket had failed somewhere allowing coolant into the EGR passage. The screws on the bottom are rusted and one appears to have had coolant leaking from it as well. There are signs of coolant deposits, light tan/ white colored.
I found this on an intake setup that I was given for free, not on my car. I am cleaning it up to swap on to my car. I guess I will use the IAC that is on my car now instead.
Old Jul 29, 2000 | 10:28 AM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
you will want to bypass the throttle body coolant anyways
Old Jul 29, 2000 | 10:57 AM
Thanks for the advice Pablo, but I did that already, the day after I bought the car.
1992rs/ss
Jan 31, 2025 05:10 PM
Jake_92RS
Jan 28, 2020 10:37 PM
86IROC112
Aug 17, 2015 02:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Jake_92RS
Aug 11, 2015 10:39 AM
