Trouble shooting............advice needed
Old Jul 28, 2000 | 04:35 PM
86Trans Am's Avatar
Just installed headers, has a cat and exhaust, no AIR, new o2 sensor, and now the car runs like crap. It idles steady but the engine shakes a lot, if that is what you want to call a rough idle. As soon as you give it gas it bogs, and stays bogged. I drove it two miles, very slowly, and gave it probably half throttle and it threw a code, 44-lean oxygen sensor. I dont really see how the oxygen sensor could cause the car to run so bad. I'm going to check the fuel presure right now.
Someone said something about a "heated" o2 sensor, no one at autozone had heard of one, can anyone tell me anything else about them?
And how do you short circuit the o2 sensor, for the time being i just used a small piece of wire to hold the o2 wire off of the headers, could this have done it?
1986 Trans Am
305 TPI
"If it's not one thing, it's another!"
http://www2.hanover.edu/hierlmeier
Old Jul 28, 2000 | 08:41 PM
86Trans Am's Avatar
has to be ready by the 12th, someone has to have had some problems like these....then again i should have known better then to try something myself....
1986 Trans Am
305 TPI
Old Jul 29, 2000 | 05:57 AM
Ski89Z28's Avatar
I don't know, sorry.
But this post will put you at the top again and I hope someone with more knowledge than me will be able to help you.
Come on guys at least he tried! Give him a hand!
Good Luck!
Old Jul 29, 2000 | 10:53 AM
Vader's Avatar
86,
The oxygen sensor relies on the exhaust system for an electrical ground. If you used fresh gaskets, anti-seize, and still have fresh paint or coating on the headers, the sensor may not be grounded well. Make sure the headers are a good ground for the sensor. You can try temporarily installing a ground strap or wire from the block to the bare metal base of the sensor and check the readings again.
You might also want to closely inspect the spark plug wires for heat damage, and double-check the firing order.
Later,
Vader
"Some Body...Someone"
Old Jul 29, 2000 | 04:05 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
Get a bosch sensor for a 93 vette (napa) there will be 3 wires one will go to a 12 volt soruce hot only when the key is on, the other one will go to a ground, Now the 2 wires I just told you about will be the same color, you can hook, it does not matter which you hook to which, the 3rd wire which will be a diffrent color is your o2 sensor wire. hook it to the one you have now. Napa sells weather connector that will plug right in to your new sensor. I think it is for a zr1 vette the other vette that year did not have a heated one.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Moroso Blue max wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
hokis
Aug 9, 2015 03:57 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
