What Free mods havent I done yet....???
I'm not to sure how to gut a cat but that sounds simple enough...
I removed the screens from the MAF, ducting has been drilled out, are there any more for free... I need a little more horse to take my friends Z... but no mo money right now...
Please help me
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
couple of mods... more on the way
Bad cop... No donut
Please help me
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
How do i do the coolant by-pass, i hadnt even heard of that one till i read this board.
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
there is an article in the tech section that tells you exactly how to do the tb coolant bypass, also port your plenum,, its free and easy. this page has both of the mods,, look here http://members.aol.com/mmmm999/3rd-degree/tips/tips.htm
Naw, im not gonna port that stock stuff, its all gonna be edelbrock soon... i hope
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
Car: 87 Monte Carlo SS
Engine: 89 IROC 350 TPI
Transmission: 700R4 rebuilt w/TCI kit
Axle/Gears: 9" from 57 ranchero unsure gears.
if you do buy the edelbrock stuff what are you going to do with your stock stuff? I need a set of runners without any dents or bad scratches so I can polish them up, if you need a set of runners Ill trade ya plus some cash. just let me know
thanks
'87 Monte Carlo SS,with '89 IROC 350,700 trans, blew up 3.73 posi stuck with crappy 2.73's neeed gears! hooker headers, flow's 2 1/2" exhaust true dualls
thanks
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
You can also do the TPI ram air. To find out more on that look in the tech section, under RAM AIR FOR TPI. I did this for under $6.00
Also, you can remove ****, like your front sway bar, spare tire, jack, back seats, ect.... What ever you wan't to spare, remove it. Less weight is good
1992 Z28 5.7 TPI 700R-4
Yeah man, they are in perfect condition except for where the throttle cables have polished it up a bit.
Everyone will know when i get my edelbrock, so just look for them in bout a month or so...
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
89 IROC-Z
305 TPI
B&M Ripper on T-5
Black and Gold
Bad cop... No donut
Doing a performance tune up is sort of a free mod, since tune ups have to be done any way, you might as well get some more horsepower out of it. A performance tune up is when you use rapid fire plugs, accel wires, cap, rotor, K&N filters, synthetic oil to name a few.
1987 Chevy Camaro IROC-Z
L98 TPI 350 (5.7L)
TH 700R-4 Transmission
Current Mods: Edelbrock TES Headers, Hooker Cat-Back System, Performance Resource Chip, 160* Thermostat, Accel 8.8mm Ignition Wires, K&N high flow air filters, gutted air box, gutted MAF sensor, Throttle Body Coolant By-Pass, Homemade Ram-Air, Falken ZIEX Z-Rated Tires.
1/4 mile times without chip:
Best ET: 15.7 @ 89MPH
Best Corrected ET: 14.5 @ 96MPH
L98 TPI 350 (5.7L)
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
You can also shim the fuel pressure regulator to increase fuel pressure. That will result in a little more power and improved throttle response.
I used a quarter in mine, pretty simple swap really, hardest part is getting the plenum off to get at the FPR.
You simply insert your shim into the top of the FPR housing, then re-assemble. What it does is increase pressure on the spring assembly in the FPR, thereby requiring more fuel pressure to force the spring assembly to open the return line.
This is the exact same thing that a aftermarket AFPR does by the way, only it uses a screw/bolt to press on the spring assembly, so it is adjustable (duh).
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Free: gut the converters.Take the smog pump off and install a shorter belt.
Cheap: synthetic oil,trans fluid, & diff. fluid.Air foil,K&N air filter,shift kit,under drive pulleys.
92 GTA(only 226 made)
ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip.
ort matched sportsman heads with 2.05 valves,64 cc,milled .015,.028 head gaskets,port matched Accel runners,port matched plenum,port matched edelbrock intake,flow matched injectors,jet hot headers and 2.5" mandrel bent exhaust,Flowmaster muffler,underdrive pulleys,slp cam,1.6 rockers,slp cold air induction,52mm throttlebody,performance resource custom chip,Dyna module,Screamin Demon coil,Accel 8.8 wires,Bosch platinum plugs,timing at 10 degrees,tb bypass,relocated map sensor,shift kit,Fairbanks billet servo,pump vane kit & 2400 stall,Torque converter lockup switch,3.42 posi with welded axle tubes,Zexel Torsen HD diff.,Summit rearend girdle,solid pinion spacer,& alloy axles.Boxed panhard bar,lakewood lca's & edelbrock strut tower brace,Jeg's torque arm,Jegs welded in subframe connecters.Performance friction pads,turbo slotted front rotors,stainless braid brake lines.Roh ZT 17x8.5 front wheels with 255/40ZR/17 tires. 17x9.5 rear wheels with 275/40ZR/17's on the street.Hoosier 26x9.5 slicks on the strip. Thread
Hotrodboba400
Dec 10, 2019 07:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
