Help with 91RS No start after park
Old May 7, 2003 | 03:02 PM
1987fbd's Avatar
So I pulled up to a Post Office and shut the engine down like normal. I came back out and went to start the car and it wouldn't. So I went to a gas station and bought a little starting fluid which did the trick, luckily I had someone with me which could crank the car over while I was squirting. It started ok and we left. I didn't think much of it till I got back to work and then tried to leave that night and had the same problem. However this time starting fluid would not get it started. If I keep spraying the fluid in it will keep running. So it seems that my car is not getting any fuel. I checked relays and replaced them. I have unhooked the fuel line and there is no fuel coming out when we crank the motor over, is that normal? I have checked the obvious like gas and spark. I hooked up a trouble code reader and get no codes.
Help this is a 305 by the way. Bone stock other than 3" catback and open element. It is fuel injected not carbed.
I thank you all for the replies in advance.:hail:
Old May 7, 2003 | 05:06 PM
1987fbd's Avatar
HELP!
Old May 8, 2003 | 09:08 AM
1987fbd's Avatar
PLEASE HELP!!!!!!
I know someone has at least a suggestion about this or any offer please help.
Old May 8, 2003 | 09:14 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like it wants a new fuel pump relay.
Old May 8, 2003 | 09:19 AM
1987fbd's Avatar
I switched the relay with the cooling fan relay as they are the same. Have any other ideas? Thanks for the reply
Old May 8, 2003 | 10:32 AM
Vader's Avatar
Can you hear the fuel pump operate for two seconds when you turn the ignition ON?
Old May 8, 2003 | 10:36 AM
1987fbd's Avatar
No I hear nothing and I am sure at one point it used to.
Would the VATS, disable the fuel pump even if the security light doesnt stay on steady or flash?
Old May 12, 2003 | 09:08 AM
1987fbd's Avatar
Update.
I finally had the car towed home and when I got it back I decided to jump in it and start it. The damn thing started so I took it for a drive, and by the way I heard the fuel pump that time. I parked it when I got home and then tried it again and nothing.
So is it some short somewhere? Maybe a fuel pump wire?
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
