A few Questions on Distributor tuning.....
Old May 7, 2003 | 07:44 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
I just got a rebuilt distributor for my L69 becuase the old one began to leak oil up into the module area.
1st: Regarding the setup on my 84', what kind of TOTAL timing do I want? I hear 45-55 degrees, but that is pretty broad.
2nd: ALL HEI's have 20 degrees of mechanical advance, right?
3rd: The # on the VAC advance canister is the # of degrees the canister gives, right?
4th: What should I do about setting base timing when changing advance springs? I.E. if I set the base timing with the stock springs on to 14-16 degrees, then I change to my lighter springs, even at 700-800 rpm I get like 20-24 degrees ( can't tell by eyeballing)
Should I set it with the stock springs or the advance springs to 14-16? I set it with the stock springs in my old dist, and that worked best, but the canister gave 12 degrees of advance rather than 20 like my new one. I can't just swap canisters cause I gave the old one for a core.
I am planning on getting an adjustable Vacuum canister soon.
Old May 8, 2003 | 01:07 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Not all have 20 degrees. You have to find out what yours is specifically.
But...
Total mechanical is king. Without the vacuum hooked up, 36-38 is typically all a SBC will want/need. Vacuum advance should be adjusted after that to avoid ping at mid-RPM, high-load cruise conditions.
You really need an advance timing light, or timing tape on the balancer. Guessing just doesn't cut it, unless the distributor is set up on a distributor machine so you know the total mechanical advance and when it is all in, and can set the initial timing at idle.
If you have an advance timing light or timing tape, the easiest way to adjust total mechanical is to remove the springs and start the car up. The weights will advance full at idle, and you can set it without reving the engine up (disconnect vacuum first, of course).
As long as it starts without kick-back, and/or doesn't ping at partial throttle, the initial advance doesn't make much difference.
Old May 8, 2003 | 10:34 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Here you go:
http://www.hotrod.com/techarticles/43300/index.html
http://www.carcraft.com/howto/24878/
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
beastin91rs
Oct 9, 2015 07:38 AM
86IROC112
Aug 17, 2015 07:57 PM
redmaroz
Aug 16, 2015 11:40 PM
