Can I change my v belt setup to serpentine
Old May 7, 2003 | 07:46 PM
crazycrocket's Avatar
Car: 1985 camaro
Yeah I've decided that my v belt setup is a royal pain and that either before or when I have the 400 ready I'm wanting to change it over to serpentine. My question is has anyone done this?
I'm wanting to use used parts off a caprice or fuel inject camaro
I have an 85 camaro with a 305 4bbl (if it matters)
Will the brackets line up?
Can I keep my higher output alternator that I have added?
Will I need to take the power steering pump or just the P/S pully?
Is it true I need a reverse water pump?
Would it be better to keep the alternator and A/C in current spots instead of switchign them if it is possible?
Does anyone have any tips about doing this?
Old May 9, 2003 | 09:55 AM
Car: 1985 camaro
ANyONE?
Old May 9, 2003 | 10:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
1. The brackets do not care what the bore is; they will not even ask you that before deciding whether to line up. As long as you use heads with the correct bolt holes, and assemble the brackets correctly, they will line up.
2. Can't see why not, if whatever particular one you bought is physically compatible with whatever brackets you choose.
3. It would be better to get the whole pump; they don't all mount the same way, and reservoirs are different shapes to clear different things.
4. Yes. If you put a belt system on it the that turns the water pump in reverse, then you need a reverse water pump. This has nothing to do with engine displacement.
5. Depends on the brackets. You probably won't have a choice. The single serpentine belt setup will switch them.
Old May 9, 2003 | 09:45 PM
Car: 1985 camaro
Okay thanks for the help. ONe more question though
Is there any difference between the power steering pump I have and one from another car like say a caprice. Or would I just be best off to find a 88+ camaro?
1992 Trans Am
May 10, 2023 07:19 PM
Terrell351
Jun 13, 2021 01:13 PM
evilstuie
Jan 9, 2020 08:29 PM
mustangdmurder
Aug 21, 2015 07:17 PM
jahblah
Aug 12, 2015 05:54 PM
