Torque wrench +extension?
Old May 8, 2003 | 03:54 AM
Kaps's Avatar
Hey, I was wondering if a torque wrench would be thrown off an accurate reading if an extension was on the socket? Need to know as I will be re-assembling my TPI manifold in a few hours. Thanks
Old May 8, 2003 | 05:27 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
not If you keep the socket-extension straight. Torque is measured as if from the center of a circle and the handle of the wrench is the outer part of the circle. As long as the nut-bolt is in the center of the "circle" it would be fine.
Old May 8, 2003 | 05:29 AM
ede's Avatar
ede
as long as it doesn't increase the length of the lever, or torque wrench, you'll be fine. the lenght from the socket to the square drive doesn't change only the height from the socket to the square drive.
Old May 8, 2003 | 06:33 AM
RJR99SS's Avatar
depends how much torque of course. and depending on the length of the extension, it could very well "twist" some.
But you may or may not know that a torque wrench isnt a very accurate way to get the right torque anyway, so might as well go for it.
Old May 8, 2003 | 07:32 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
No, the socket extension will not alter your Torque readings.
Old May 8, 2003 | 03:48 PM
MikeS's Avatar
Actually, adding a longer handle on your torque wrench shouldn't change it either. The gauge part of it stays in the same spot.
Old May 8, 2003 | 04:03 PM
rezinn's Avatar
Nothing you do will change the reading dramatically, and the torque wrench may not be completely accurate in the first place so it probably doesn't matter much. When using an extension I always try to keep the wrench perfectly straight(or perpendicular, actually) anyway.
Old May 8, 2003 | 04:13 PM
Kaps's Avatar
Thanks to all, Anyone know the torque specs for a tpi manifold and rest of the tpi stuff? My haynes manual conveniently has a few important pages ripped out of it
Old May 8, 2003 | 04:21 PM
MikeS's Avatar
Mine is next to my desk!
Intake runner-to-plenum 15 to 20 ft-lbs
Intake runner-to-intake manifold 15 to 20 ft-lbs
Throttle body-to-plenum 18 ft-lbs
Fuel rail-to-intake manifold 18 ft-lbs
IAC valve (1985 to 1989) 13 ft-lbs
1990 up 30 in-lbs
Schrader valve 7 ft lbs
Old May 8, 2003 | 04:24 PM
formularpm's Avatar
Car: '89 Formula
Engine: 355
Axle/Gears: 9 bolt
Runner to manifold bolts are 25 ft-lb according to Alldata, and manifold to head bolts are 35 ft-lb. It also wouldnt hurt to recheck them after the car has been driven for a few days.
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
