Fuel Pump Not engaging
Old May 8, 2003 | 06:47 PM
Wolf75's Avatar
Ok I'm at a lost as to what to do next. Went to start my car after storing it for the winter. Would not start. Found I had a bad altenator, so I had that fixed as well as a new battery.
Car would turn over ,but still wouldn't fire. Replaced the usual suspects, distributer, HEI coil, ignition module, plugs. Still nothing.
Finally I noticed that I didn't hear my fuel pump come on. Checked the fuse it was ok, replaced the relay, then checked voltage. Had 12 volts all the way to the plug that is mounted in front of the tank. Figured it must be a bad fuel pump.
Replaced it, still nothing. Read my books some more, replaced the oil pressure switch. Still nothing, I'm starting to lose my mind. I have no ideas where I should look next.
Any help anyone could give me would really be appreciated.
Brian
Old May 8, 2003 | 09:16 PM
Wolf75's Avatar
The car is a 1985 TPI Trans-Am, 305, auto.
Brian
Old May 9, 2003 | 08:57 AM
Vader's Avatar
Wolf,
Sorry you went through all the trouble to change the pump unnecessarily.
You can test the pump and wiring by applying a 12VDC source to the large tan wire at the pump relay connector, or at the 'G' terminal on the ALDL connector inside the passenger compartment.
The uncertainty of using the ALDL is that the power must be routed through the NC contacts of the relay, so if the relay has a problem, the test may not be conslusive.
The circuit looks like this:
Old May 9, 2003 | 09:16 AM
Vader's Avatar
<h1> OOPS! </h1>
Disregard that!
that data was for an '86-'88 TPI.
Your '85 is slightly different, and feeds the power to the fuel pump on a larger RED wire at the relay, and ORANGE wire at the ALDL. However, the ALDL terminal is still 'G'. The rest of the schematic for the fuel pump is the same, but don't save the schematic for the MAF power system, since it is different on your '85 as well.
Old May 12, 2003 | 07:10 PM
Wolf75's Avatar
Thanks Vader I'll give it a try sometime this week. I'll post what I find.
Brinkkl2000
Oct 3, 2016 11:52 AM
Irocz_89
May 12, 2011 06:05 PM
JohnTheBull
Mar 26, 2007 03:06 PM
Just Bill
Jul 30, 2006 03:04 PM
ColinOpseth
Jul 13, 2002 09:38 AM
