4 bolt vs. 2 bolt main
![](https://www.thirdgen.org/forums/images/ranks/tgo10.gif)
Car: 1986 Camaro Z28
Axle/Gears: 3.73 Posi
What is the difference between the two? Is one better (or more coveted) than the other?
Thanks.
1985 Camaro Sport Coupe
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
4x2, 4.3L, 3.42 rears
Decidedly slow
Thanks.
LG4, 3.08 rear, A4
Bone Stock
1999 Blazer
Decidedly slow
1 Post
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
The inner main bearing caps of the blocks are different. The 4-bolt main bearing caps have four bolts instead of two. It is stronger and more rigid.
Yet, the two-bolt is no slouch, either. Probably good for most street-going engines. In fact, a 2-bolt block can be converted into a splayed 4-bolt block, which is considered to be stronger than the factory 4-bolt mains. All this talk of strength is confined to one thing: Keeping the crankshaft in-line. Just as critical are the quality and condition of the rod bolts, the bearing clearances, the type of connecting rod, and the quality of the piston. In addition, shot-peening and balancing of the reciprocating assembly aid in strength/survivability of a short block. Finally, the block itself must be dimensionally correct for maximum strength. A 2-bolt block which has been magnafluxed, line-bored, decked, counterbored & de-burred will probably be stronger than a 4-bolt which has just been yanked out of a truck.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines,
5-point racing harness, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Speed-sensitive steering conversion, underdrive pulleys, Crane Hi-6 & more. 1.05g skidpad verified.
Daniel Burk
UltRoadWarrior9
09-02-2015 08:24 PM
