Smog Pump Delete Pulley
Old Jul 29, 2000 | 04:41 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Hey all. I met a guy at the Camaro/Firebird vs. Mustang day at E-town and he had removed the smog pump when he changed the motor but got a Smoh Pump Delete Pulley from GM to keep the serpentine system functional. He said that it can be ordered from any Chevy dealer and is listed in the catalog for "off road use only"
Does anyone know how I could get the part number?
Steve
Old Jul 29, 2000 | 04:53 PM
Guest
Guest
Posts: n/a
Why bother?
https://www.thirdgen.org/tech/serpentine.html
Old Jul 29, 2000 | 05:06 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Why bother? because I do not want the extra weight in the front end or the clutter that comes with it when I have to pull the valve covers routinely to check valves on a solid roller cam. I just need the part number that GM has in their catalog that is an idler pulley that is there in place of the actual smog pump
Old Jul 29, 2000 | 05:10 PM
Guest
Guest
Posts: n/a
I guess you cant click on a link?
Old Jul 29, 2000 | 05:12 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
i clicked on it and if no one can tell me the part number i will go that route, but I would to get the pulley if possible. Thanks for the link though.
Steve
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
Bwhahahaha *sits back and grabs popcorn awaiting fastbirds foot insertion to mouth*
Old Jul 29, 2000 | 05:15 PM
Pablo's Avatar
Car: Turbo Buick
Engine: 3.8 V6
dang just missed it
Old Jul 30, 2000 | 09:16 PM
lucas's Avatar
not to bright is he?
Old Jul 30, 2000 | 10:20 PM
raven350's Avatar
Car: '89 Pontiac Firebird
Engine: 5.7L
Axle/Gears: 10-bolt w/ 4.10 and Eaton Posi
What they are trying to tell you FASTBIRD, is that you do NOT need the Air Pump delete pully setup.
You can just run the belt in a different route, and all of your pulleys will still turn the same way.
They gave you that link to the article to save you some money.
Now, if you are talking about the A/C delete pully... That is a different matter all together....
Sportsman II 72 CC heads, Edelbrock 1 5/8" headers and Edelbrock cat back exhaust, hi-flow cats, Trans-go shift kit, SLP cold air induction, SLP roller camshaft, 24lb ADS injectors, AFPR, 3.45 rear end gears, and other goodies...
evilstuie
Jan 9, 2020 08:29 PM
italiano67
Dec 11, 2016 09:21 AM
LittleFranks
Sep 17, 2015 12:22 PM
BlackphantomZ28
Aug 21, 2015 07:12 PM
actionj
Carburetors
Aug 16, 2015 09:51 AM
