Just installed 1.6 rockers
Old Jul 30, 2000 | 08:12 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
Took me roughly 3 hours. Really easy. Car seems to have gained some more power. Any questions feel free to ask.
1986 CAMARO Z28 -> 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.23 posi, reinforced LCA's, Subframes connectors, front LCA poly bushings, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.32@ 106.1MPH Next mods-> homemade ram air, B&M shifter.
Old Jul 30, 2000 | 08:37 PM
S92RS's Avatar
I'm curious, but what kind did you get? I'm planning on getting a set of 1.6's for my car, but haven't decided on which ones to get.
What cam are you running? The 1.6's give you more lift? What kind of heads do you have on the motor. I'm asking because in your sig, you are running a 13.32ET. I would like to get my car down in that range. I have a carbed 355 in my 84 Z28 and am looking to make it quicker.
Steve
1984 Z28, non-computer 355
Edelbrock Performer carb and intake
214/224, .442/.465 lift cam
Hedman headers, and 3" Flowmaster exhaust
Powertrax Performance Locker with 3.23's, Lakewood LCA's
Nose, bumper and ground effects from an 89
Best ET: 14.537 @ 93.67 MPH
http://members.fbody.com/s84z28
Old Jul 30, 2000 | 08:56 PM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I just got the stamped steel 1.6 rockers. No roller bearings, I have reasons but they are irrelevant right now.
Whatever is not mentioned in my mods list, as far as the engine, is stock 89' vette internals. It's just a 350 bored 10 over with stock roller cam, 3rd gen f-body/truck center bolt valve cover heads, 9.5:1 compression, and hyperutectic pistons. I think the reason my engine runs soo well is because it is properly matched.
The car has all pluses on it's side on it's side. It hooks well, shifts fast, is geared right, and never bogs or misses a beat, it also only weighs 3325 without driver and half tank gas.
I hope to get it in the 12's with stock heads, cam, no nitrous or supercharger.
Old Jul 30, 2000 | 09:28 PM
S92RS's Avatar
Thanks for the info. I might get the Crane Energizer 1.6 full rollers for $169 through Summit.
My car is having a bogging problem that I believe is carb related. I have a 600 Edelbrock, that I may swap for something else. How is that Holley 650 DP running? My car is my daily driver. I drive it to work everyday. I don't know what I'm gonna get yet if I do swap it out.
Old Jul 31, 2000 | 01:17 AM
JDMZ28's Avatar
Car: 2KGTP
Transmission: 4T65E
Axle/Gears: 2.93
I love my holley, lots of power. Bad part is my mileage went from 19 to 14 miles per gallon. It's a quadrajet replacement carb, hooks up to the stock setup, and it's a spread bore. If the engine is heated up I can floor it at basicly any rpm or gear and it doesn't bog.
Cameeeero
Sep 18, 2015 04:00 PM
LT1Formula
Aug 20, 2015 09:36 PM
Dialed_In
Aug 20, 2015 01:45 PM
Cameeeero
Aug 20, 2015 03:06 AM
happyhapka
Aug 15, 2015 04:42 PM
