Oil in distributor!
Old May 10, 2003 | 11:52 AM
Odyssey's Avatar
Oil in distributor!
I'm running a stock HEI distributor (for now) and yesterday I took off the cap to mess with the springs and weights. Well, I saw a big puddle of oil at the base of the distributor housing, all around the pickup coil. So I took it out and cleaned the hell out of it. What would cause this though ? Is there some some sort of gasket, o-ring, etc that seals the top part of the distributor from the pressurized oil at the bottom of it ?
Old May 10, 2003 | 12:11 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
oring, mine has this problem too but i havent gotten around to pulling the distributor yet.
Old Oct 11, 2003 | 10:11 PM
stan-85-Z's Avatar
Car: 1985 Z-28
I have the same problem. Where in the distributor is the o-ring located and where can I get one?
Old Oct 12, 2003 | 12:32 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
The o-ring is located right below the distributor base (where it sits even with the block). Dont know where you can get one but I imagine ask a few auto parts stores...they might be able to order them. It's an easy install. Just yank the distributor, slide the old o-ring off, lube the new one up a little with some oil, slip it on, and seat the distributor back in the same way it came out.
Hotrodboba400
Dec 10, 2019 07:07 PM
camarohelp
Sep 22, 2015 03:19 PM
Gunsbee
Sep 7, 2015 07:10 PM
Jlanz55
Sep 6, 2015 03:05 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
