think i know why my car never idled/ran right now
Old Oct 10, 2003 | 08:00 AM
85IrocNOH's Avatar
Car: 85 Iroc-Z
Axle/Gears: 10-bolt 3.42
check it. always wondered why the Iroc never idled or ran quite like it should......
drivers side head, cylinder 7
heh....
Old Oct 10, 2003 | 11:33 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
um isnt that normal? if your talking about the black crud, if i'm correct that is the exhaust valve and they get like that
Old Oct 10, 2003 | 11:46 AM
jasonbennett's Avatar
take a closer look. there is a big crack in the chamber
Old Oct 10, 2003 | 10:33 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
yea. i bought new 416 cast heads and ground all the valves and seats. only problem is, when we went to change the cam, there was copper showing on the cam bearings. i imagine the rod and main bearings aren't much better off since the bottom end hasn't ever been touched. so now i gotta decide whether to take the 305 to a machine shop and have it all redone or to just invest in a 350.
Old Oct 11, 2003 | 12:42 AM
EvilCartman's Avatar
Car: '82 Z28
350 at this point would probably be just about the same amount of money and you'll get more out of it.
Old Oct 11, 2003 | 12:59 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
yea i know. i got until spring break to save up for it. that's when i'm gonna put the motor and tranny back in.
Old Oct 11, 2003 | 03:02 PM
Damon's Avatar
Hey- don't overlook the weird wear on the exhaust valve guide on the top side (last pic). Something chewed that sucker up bad. Busted spring???
Old Oct 12, 2003 | 01:08 PM
85IrocNOH's Avatar
Car: 85 Iroc-Z
yeah. that was gonna be one of my questions. that whole head was screwed up. but that valve guide is on the same cylinder as the crack. i was wondering if it had anything to do with that or if there could've been another cause. i know the spring wasn't busted on that. it didn't really feel weak(er) than the others i took off either. what else could cause this to happen? i suppose it doesn't really matter b/c i bought another set of 416 heads, but i'm just curious what would've caused this.
that cylinder was filled with antifreeze when i pulled the head off too......looks like i know where my antifreeze has been disappearing to.
i know this engine was overheated in a parking lot at mcdonalds by the retarded previous owner and it warped a head. from what i could gather from her, the car never ran right after that. methinks she got the shaft from the place that charged her $700 to "fix" it.
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
