Simple StealthRam question
Old May 12, 2003 | 02:20 AM
Odyssey's Avatar
Hello everyone. I have a question for people that installed StealthRam's in their Fbodies (or people that know this info).
What do I need to buy to adapt my stock TPI fuel lines to the StealthRam's fuel rails ? I've searched for this info everywhere and I all I found was D Flynn's list of things he used, but that says he cut the fuel lines somewhere and I didn't do that. So what did you guys that installed the StealthRam do for fuel lines ?
Old May 12, 2003 | 09:22 AM
Kevin Gray's Avatar
This should help.
https://www.thirdgen.org/techbb2/sho...tealthram+fuel
Old May 12, 2003 | 09:42 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
i know holley sells a fuel rail kit for the stealth ram, you may have to buy that. i don't know if the stockers will work on the HSR or not.
Old May 12, 2003 | 10:46 PM
SMasterson's Avatar
Car: '89 GMC Pickup
Engine: 383 SBC Stealth Ram
Transmission: 700R4/VIG 3200
3' of steel braided hose, cut in two equal lenths.
AER-FCA0603 Aeroquip Stainless Steel Braided Hose $15.95
4 straight -6 AN fittings
AER-FCM1012 Aeroquip AQP Fittings $5.95 4 $23.80
2 Earl's adapters, 14&16mm
EAR-9894DBH $7.99
EAR-9894DBJ $7.99
Parts Total: $55.73
These are the Summit numbers from my email confirmation when I ordered mine.
Removed the rubber lines and attached these Earls adapters to the stock braided lines, screwed on the '6an hose fittings and lines, and then to the rear of the HSR fuel rail and FPR.
Bubbajones_ya
Aug 31, 2015 12:02 PM
355tpipickup
Alternative Port EFI Intakes
Aug 26, 2015 04:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
redmaroz
Aug 16, 2015 11:40 PM
camaroken83
Aug 10, 2015 11:35 AM
