Installing Distributor
Old May 12, 2003 | 03:58 PM
Acidtalons's Avatar
I am attempting to install my new MSD distributor, however it fits down into the engine except for the last ~3/8 of an inch. I have attempted to turn the oil pump shaft but it doesn't seem to want to fit down there no matter which direction the pump shaft is facing.
Also one of the rubber O-rings on the distributor broke, how important are these?
Old May 12, 2003 | 05:09 PM
si_camaro's Avatar
Car: 85 Z28
Engine: LG4 modified
Re: Installing Distributor
I recently installed my distributor with a little difficulty. I too attempted to turn the oil pump shaft but to no avail. Try bumping the engine a couple of times. As long as the clamp which holds the distributor in place is not too tight, the drive should align itself with the oil pump shaft. It did for me anyway.
Old May 12, 2003 | 06:58 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
did you try wiggling the rotor back and forth? thats how i normally gettem in.. and that o-ring is pretty important unless u like oil everywhere hehe
Old May 12, 2003 | 08:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I usually just turn the oil pump shaft a little bit at a time. You've got to position it so that the distributer shaft will grab it as it's seating, not when it's fully seated.
Frozer!!!
Jan 19, 2024 04:55 PM
Caspar
Jun 19, 2016 11:19 PM
djmarch
Aug 19, 2015 12:07 PM
86IROC112
Aug 17, 2015 07:57 PM
stalkier
Aug 7, 2015 04:49 AM
