new plugs,cap,rotor,wires and now it wont run....
Old Jul 28, 2000 | 03:31 PM
warmachine1971's Avatar
wtf?! should i go get a gallon of gas and a pack of matches or is there a way to fix this thing?
Old Jul 28, 2000 | 04:14 PM
niu2001's Avatar
From: DeKalb, Streamwood, Arlington Heights, IL, USA
Are you sure you bought all of the right parts? You could have possibly gapped the plugs wrong, but that is doubtful.
What kind of engine is it?
Did you forget to plug in wires that go to the distributor.
Make sure the plug wires are on right, if not, this will cause the car not to run. Find the fireing order and check the corespondence with the distributor cap. This is most likely the problem.
Good luck
-NIU2001
Old Jul 31, 2000 | 06:09 PM
'91RSS's Avatar
I had the same problem with my car so i put it in the shop, wasnt easy for me to do, and it was the copper coil around the rotor under the distributor cap, it was fried so they had to replace it.
91 Blue RS w/ASCD SS hood, K&N air, Flowmaster 80 series muffler, and Hypertech superchip.
Old Jul 31, 2000 | 07:06 PM
GOFASTER's Avatar
Car: 1991 Super Sport
Engine: 388 ci
Transmission: TH-700R4, 3500 Stall
Check you firing order. You may have put the wires on wrong, and check you plugs, they could also be the wrong type.
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
GouldyGTR
Aug 21, 2015 10:43 PM
Winchester1094
Aug 18, 2015 10:23 AM
