What does "Delete" mean?
Old Jul 30, 2000 | 11:23 PM
Topgun's Avatar
Ok, Question. what does Delete mean in the codes. like one rpo code on my car translate into "Spedometer Delete" What does that mean? Sorry for posting this on the tech board, i just thoughti would get a more prompt and better response. Sorry if i offened anyone.
EMAIL: CTopgun5@aol.com
_______
84' Z28
350 Ci 4 Bolt Main with all L69/HO Parts
4 BBl Carb
160º Thermostat
K&N High Flow Filter
700R4 Trans
15X7 Standard Z28 Wheels, With 215/65R15 BF Goodrich Comp T/A HR4 Tires
Charcol in Color
no T-tops, but wish
As FiremanZ28 says "Friends don't let Friends Drive Mustangs"
Pic of my Z28, thanks to ZZ4 and his web page: Http://www.geocities.com/ukzz4iroc/z28camaro.jpg
Old Jul 30, 2000 | 11:29 PM
Chris Luongo's Avatar
Here's an example. From the factory, the car comes with an AM/FM radio as standard equipment. A cassette deck and the Bose system would be optional, and each have their own RPO codes.
But sometimes, a customer could order the car with no radio or speakers whatsoever, and save money. In this case, the RPO code might say "AM/FM radio delete". Like how the 1LE cars all have the air conditioner delete option.
I'm just taking a wild guess here, but perhaps your car has an options package that included a 140mph speedometer, or a "trip meter," but for some other reason, the optional speedometer was deleted.
Old Jul 30, 2000 | 11:32 PM
RSS's Avatar
RSS
I guess delete just means that your car didn't get that part. Like if it says "AC delete", then your car won't have AC.
Also, how did you get that degree mark in your sig? I just used the * but I like yours better.
RSS says that too. Look below. Actually, I think I was the first person to ever have it in their sig. But I'm glad that other people are using it. Ford sucks!!!
92 RS (Rice Sucks) 305 TBI 5 speed T-tops AC stock 16 inch aluminum wheels
14X3 open element, 3.73 gears, posi, dual 2 inch bendable exhaust, no mufflers or cats (kinda loud), 160* thermostat, relocated IAT, weight loss, lots-o-free mods and one hell of a crazy driver.
"Friends don't let friends drive Mustangs."
Old Jul 30, 2000 | 11:53 PM
Blue502's Avatar
I tend to agree with Chris on this one. I doubt that it would be legal for GM to sell a new car without any speedometer, so it probably means you didn't get an optional one that was included in a package, and instead got the standard one.
Now why they would delete this is something I couldn't answer. Do you by any chance have a km speedo, or was your car sold in Canada with a mph one? Only things I can think of.
'86 Camaro Sport Coupe
Old Jul 31, 2000 | 12:20 PM
SmokedU's Avatar
Yeah, what was said. Like if you order a car with a package called "sport group" or something, on say, a V6 mustang. They allow you to select Spoiler Delete so you will have everything in the sport ground exept for the spoiler.
Old Jul 31, 2000 | 06:43 PM
Vader's Avatar
Originally posted by RSS:
... how did you get that degree mark in your sig? I just used the * but I like yours better.
RSS,
We old DOS guys remember a lot of the old ASCII codes by heart. Hold down the [ALT] key while entering [2] [4] [8] on the numeric keypad (Num Lock ON, of course). The resultant character should be the ASCII "degree" symbol. There are about 254 more of them, too. Your other option is to insert a superscript lowercase "o" after the text, if you know the codes...
As far as a speedometer adapter or speedometer key delete, this usually accompanies an RPO 'D9A' - a VSS. The different speedo heads required drive gears other than the standard item, so the build sheet reflects that change.
Later,
Vader
Old Jul 31, 2000 | 06:45 PM
Vader's Avatar
BTW - If you're going to test your signature, please do so on a board other than "Tech", so we don't clog the archives.
Thanks.
Later,
Vader
"Some Body...Someone"
Old Jul 31, 2000 | 07:37 PM
John Millican's Avatar
Car: 1997 Jeep Wrangler
Engine: 4.0L
Transmission: 5 speed
Axle/Gears: 8.8 rear, 4.56 gears, 4:1 transfer
Originally posted by Vader:
RSS,
Here's the extended ASCII code chart, most work but a few Windows refuses to recognize.
http://www.jimprice.com/ascii-128-255.gif
86 Camaro Sport
383 Speed-O-Motive Crate Engine, Trick Flow Heads, 58mm Accel TB, 3.73 Auburn Pro, SLP Cold Air Induction and Headers, Dynomax Cat-back, Serpentine belt setup.
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
Zell1luk
Sep 29, 2015 10:36 AM
