Just ordered my LPE cam today, right one or wrong?
Old Jul 31, 2000 | 01:22 PM
Mike '91 Z28's Avatar
216/218 .493/.501 112deg
It's going in a sd 305tpi with S/R Torquer heads and 1.6 Roller rockers, and a TPIS base and runners.
Old Jul 31, 2000 | 04:49 PM
Box of Rocks's Avatar
Mike,
It should be just about right for your combo. since you're going to use 1.6 rockers, make sure you get valve springs and retainers to match your setup. Also, you'll need to check for clearance on the pushrods as they orient to the opening in the heads.
You may need to use a round file to elongate the holes - which turns the holes into slots, thereby letting the pushrods clear with the 1.6 rockers. Good luck.
BOR
Old Jul 31, 2000 | 08:22 PM
82z's Avatar
82z
good call
82 z28 350cid, vortec heads, comp 262h cam, Holley 600cfm carb, 2in twice pipes, MSD ignition, turbo 350 trans, 3.73 posi
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
Cameeeero
Sep 18, 2015 04:00 PM
spaigo
Aug 21, 2015 07:46 PM
Electro_X
Aug 19, 2015 07:59 AM
Fronzizzle
Aug 9, 2015 01:15 PM
