BFG Drag radials ???
What's the best way to get traction with these tires? A buddy of mines has a '72 Camaro with a worked 383, TH400, & 4.10 gears. He's not getting good traction of the line. With the wheel spin, he's still turning very low 12s. Should he do a heavy burnout with them or what? If any of u r using these tires, what works best 4 u?
A friend of mine had a set on a big block '68 Camaro and another set on a 355 S10....they work ok on the street, but the stink at the track. Do a light burnout to clean them off, but don't really heat them up. Also, don't drop to much tire pressure since they have a stiff sidewall.
Good luck!
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,Hypereutectic pistons,9.8:1 compression,HPC Coated RPM intake, Edelbrock 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, K-Motion springs, Comp Cam 1.6 roller rockers, Lunati adv.292/230@.050 with .512 lift,Crane pushrods,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with B&M 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Good luck!
The BFGs work great at the track. I run between 16 -18 lbs of air in them, depending on conditions. They do take a healthy burn out to get them stickey. These tire do not have the same compounds as a street tire. I give them a GOOD 2-3 second burn out. They do work better when they get a little worn. By the way they are NOT GOOD on the street. Once it gets a little wet look out.
Hank
87'IROC Z28
Hank
87'IROC Z28
Transmission: 4L80E/4L80E
M/T's are the favorite for street class big boys here. I don't personally have them, but know an '83 Monte and '66 Impala w/454, and '74 Chevelle w/502 that run 11's at 5800' Bandimere. All say the M/T's are much better than BFG's, and a good burnout (4-5 seconds after smoke) gets them there. They run at lower pressure than what the manufacturer says, 12-15 psi.
[This message has been edited by five7kid (edited July 31, 2000).]
I agree five7, MT ET street's are the way to go for the weekend cruise. And Hank, I meant "on the street" racing, not slalom in rain. Your right there, they do stink in water. But on somewhat street or blacktop, I have found they do ok on the street, but ET Streets are taking over popularity here too.
Thanks again, I'm sure he'll be pleased with all the feed back. The BFGs he has r still fairly new and this is his 1st time 2 the track with the car since it's been finished. The car is definitely capable of 11s. I'll tell him 2 break the BFGs in 1st before the switch 2 M/Ts. Thanks.....
[This message has been edited by Cntrvrsy (edited July 31, 2000).]
Watching Horsepower TV awhile back I say an episode where they were talking with the NMCA boys at an event. They all said the BFG's worked great once they got the tread off. I don't know personaly though. I have a good freind running M/T Sportsmans on his 600hp '73 Z/28. He doesn't like them much, but then he hasn't had anything to compare them to. Just my 2-cents.
1984 Z/28
GoodWrench 350, Edlebrock Performer intake, MSD 6AL Super HEI kit, Crane CompuCam 2040, Edelbrock headers, Catco cat, Flowmaster aftercat, K&N, Custom 700R4, B&M Megashifter, Eibach springs, KYB GR-2 struts/shocks, Jegster adj LCA's, Lakewood adj panhard bar, BFG Comp T/A's, 160* stat, AutoMeter Pro-Comp COOLANT GUAGE.
1984 Z/28
I back up to the water without getting in it and start smoking them (without holding the brake) until they catch and launch me foreward. I then back up about 1/4 of a mile, listen to the track dude gripe and threaten me, stage, and go. They will hook great under this method, I have pulled 1.7 60 foots with them.
'91 Z28 Blue/Silver ZZ4/ZF6
328.4 RWHP 363.5 RWTQ
