Unbolting the Engine
Old May 15, 2003 | 04:36 PM
Ivon1877's Avatar
Car: 1990 Camaro RS with T-Tops
Engine: 312 TBI(305) 0.040 over
Transmission: out of a v-6 s-10 blazer!
I have a 90 rs 305 tbi. What is the best way to unbolt the engine from the tranny?
Old May 15, 2003 | 04:39 PM
MikeS's Avatar
How come you're separating the two? Which one are you pulling? You should be able to get to all the bolts from underneath ok. If you are removing the engine, or removing both, you may want to leave them attached. If you're just removing the tranny, then you'll want to go ahead and separate them.
Old May 15, 2003 | 04:41 PM
Ivon1877's Avatar
i am pulling the motor because it had a rod knocking!
Old May 15, 2003 | 04:47 PM
Ivon1877's Avatar
i crawled under the other day and tried to reach the middle set and my hands are to big.
I saw somewhere you could remove the cross member and lower the rear end of the tranny will it give me enough room.
I am trying to keep this inconspicuious, not supposed to do any car work in my neighborhood!
U.S.Navy!
Old May 15, 2003 | 05:10 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
go to sears or some place that sells alot of tools and look for about a 3foot extenstion for like a 3/8ths drive and that will work. thats the easiest way to gettin to those bolts.
Old May 15, 2003 | 05:28 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Pull them out together and put them in together.
It makes it really easier.
We did it this way on 2 setups we installed, LT1/4L60E's into an 82 T/A and my 86 T/A. did the 82 on saturday and mine on sunday.
Old May 15, 2003 | 05:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Take out the distributor first; you have to anyway. When you do that, you can just stand there and get to the top bolts from above with a box end wrench.
Old May 15, 2003 | 06:26 PM
ede's Avatar
ede
3' extension, flex socket, and impact wrench
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
gwade12
Aug 8, 2015 08:17 AM
