Noisy IAC
Old May 16, 2003 | 05:23 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Noisy IAC
When trying to set my min idle; I installed a jumper at the ALDL, and then turned ign sw to "run", which is supposed to make the IAC drive full closed.
When I went to disconnect the IAC, I noticed is was making a noise. Kinda like it was still trying to move. Gave it a couple of mins, but it continued to make noise. Is the IAC bad?
It was removed and cleaned abt a week ago.
Old May 16, 2003 | 07:39 PM
rockfourone's Avatar
if it still makes noise after a few seconds then id be worried. mine has always made a "eletric motor" sound when i turn off the key. it always stops after like 4sec though. if your suspicious, id go ahead and buy a new one. i mean how much are they like $15-20? say $30 at most? you cant go wrong
Old May 16, 2003 | 09:15 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
it will make that noise as long as the terminal is jumpered, dont sweat it. The IAC (ECM) is continously trying to extend the pintle with the jumper in place.
Old May 17, 2003 | 05:09 AM
Vader's Avatar
Yup. With the ALDL jumper in place, mine always keep clicking away until they are unplugged or the ignition is turned off.
Old May 17, 2003 | 03:02 PM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Thx guys. That's one less thing piece of the puzzle out of the way.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
