car alarm...
Old Jul 30, 2000 | 12:07 PM
8Formula7's Avatar
car alarm...
I also posted this in Car detailing and appearence and detailing section...
I'm installing a car alarm: Audiovox AA-9347. Has starter kill, parking lights flasher. Bought all the necessory hardware (relay). I need to gain access to wires from ignition switch. Where are these wires? What colors are they? Please help...
1987 Firebird formula, power windows (no power locks), 4 barrel, gauge cluster (tach, speedo, temp, volt, oil pressure, fuel), NO accessory in ignition (in other words, I can't turn the key towards me to accessory position, there is none)
Thanks,
Kyle Donohue (Ponty87bird@aol.com)
Old Jul 30, 2000 | 03:11 PM
Scott 87 IROC-Z's Avatar
Car: 87 IROC-Z28
Engine: 377ci, Brodix Heads, Solid Roller c
Transmission: 700-R4 w/ Yank ST3500 Converter
When I installed my Crimeguard on my other
Camaro, I had to drop the steering column to giain access to the wring harness there for the starter kill. Look in the Haynes or Chiltons manual for the wiring diagram of the ignition to fins the correct color wires.
87 IROC-Z 305 TPI
MSD 6AL & Blaster II Coil, Richmond 3.73, K&N Filters, TPIS Airfoil, TPIS AFPR, Custom Cold Air, KYB Shocks & Struts, Ported Plenum Runners and Manifold, Comp. Eng Subframe Connectors, SLP Headers, Borla 3", Hi-flo cat, TH700-R4 with TCI Pro Super Kit and 2100 rpm stall converter
www.acsu.buffalo.edu/~ermer
***** FOR SALE *****
Old Jul 31, 2000 | 10:29 AM
8Formula7's Avatar
Thanks...
Old Jul 31, 2000 | 10:50 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
You might also want to intercept the fuel pump power line, or the pink/black "IGN" wire that goes to the remote HEI coil. Please use a relay tho!!!!
I intercepted the ECM IGN fuse. The result is, the car cranks & cranks & cranks & cranks, but won't start.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.v6fbody.com mailbags
Old Jul 31, 2000 | 06:50 PM
Ritchy's Avatar
Your starter wire runs up the front of the motor just to the left of center (passenger side). You can trace it by seeing what color coding it has at the starter. Use a volt meter and shave the insulation before cutting it to be sure. It is a thick wire, @ 10 gage.
BTW: I agree with using the coil method also as its not so obvious that you have an alarm and if they run the battery down they can't steal it so easy. I personally do not use an alarm anymore as they broke my window to see if it was an audio alarm and then just took what they wanted. I use a hidden kill switch.
86 FB stock 305 Qjet South California emissions
Old Jul 31, 2000 | 09:11 PM
chrisfrerick's Avatar
you can find most of your wires just off to the right of the steering column
thick red=12v
thick pink=ignition
thick orange=accessories
thick yellow=starter sometime but rare it is a thick purple.
doortrigger is white at courtesy lamp down by kickpanel
lightflash is brown at headlight switch or gray at shiftplate light.
Old Aug 1, 2000 | 02:12 PM
8Formula7's Avatar
Thank you all for the helpful info...
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
