that's just what I figured(slp header install)
Old Jul 31, 2000 | 10:22 PM
KK87GTA's Avatar
I wondered about the starter removel, and the steering colum was a new one. Slp told me just change the mounts on the motor, have no idea how to do that on the garage floor. I have never been able to change the starter without taking off the solonoid anyway
kevin k
thinking about headers.
Old Aug 1, 2000 | 06:47 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Same here - just ordered mine Friday, so any day now. Only thing is, I'm not putting them in any time soon, but it's nice to find out and see what everyone else is having to do for the install. As for starters, I'm with you on that one. My original came out OK, but the replacement would not go in without removing the solenoid. Man, was I ever pissed! Must've just been having a bad day, I guess. What pissed me off even more was to do all that and it wasn't the problem after all.
Old Aug 1, 2000 | 08:07 AM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Did you get the 1 3/4" headers? So I am guessing that your header rubs against the steering arm? Mide does too. It sucks. Slp also told me to change the motor mounts and it will be ok. But I am skeptical. I didnt realize how much of a pain it is to change the mounts with the engine in the car and the front suspension in too. So now I have to take the springs out. yeah yeah I could do it with the springs in but it will be a lot easier to do it without them in. Let me know how it works out for you.
James
Old Aug 1, 2000 | 09:47 AM
Mike 25th's Avatar
I posted the other question... The motor mounts are inpossible I thought about removing the center bolt from the motor mount, jacking up the motor enough to slide the header in. I'm going to try the pass side tonight (starter removal) but the pass side is aready pretty close to going in. Let me know how you guys make out.
Old Aug 1, 2000 | 09:54 AM
Bob R's Avatar
Hey Guys,
I just did my SLP header install a few weeks ago.(1 3/4") You are right about the motor mounts, but I didn't pull the starter. Those motor mounts are no a easy thing to do. Can you say patience?
Bob R
(ROCN-Z)
89 IROC L98
Old Aug 1, 2000 | 02:37 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
For the motor mounts i took it to a mechanic, to much of a PITA. I had them install energy suspension polyurethane bushings.
For the driver side i had to remove the stearing column to get the headers in, but they do not rub. And on the passenger side you do not need to removed the starter but you will have to bend a metal pipe (coolant line), so it doesn't rub.
89 GTA 350
Jet hot SLP headers,flowmaster force 2,no cat's,SLP cold air,MSD 6al,jet chip stage 2,march pulleys,ported plenum,air foil,shift kit,B&M megashifter,180 stat,alston SFC,spohn LCA relocation brackets,free mods.
0-60 5.48s
E.T. 14.02@98.9MPH (corrected)
Old Aug 1, 2000 | 02:39 PM
Tony89GTA's Avatar
Car: 89 GTA
[This message has been edited by Tony89GTA (edited August 01, 2000).]
Old Aug 1, 2000 | 02:40 PM
Tony89GTA's Avatar
Car: 89 GTA
Old Aug 1, 2000 | 02:50 PM
85Z28's Avatar
Car: 85z28 // 97 Hawk
Engine: wore out 360 // LT1
Transmission: 700R4 // 4L60E
Axle/Gears: 3.73 // 3.23
i dont know cause we put my headers in when we had the motor out o yea and we didnt put slp's on ther either
shucks
85z28
Chad Young
if you want to see my mods go herewww.geocities.com/sxt7camaross
[This message has been edited by 85Z28 (edited August 01, 2000).]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
Wesly_66
Aug 26, 2015 09:55 PM
TheJoeY88
Aug 13, 2015 06:51 PM
drathaar907
Aug 6, 2015 04:20 PM
