wont idle unless egr valve is wedged up
350 tbi wont idle unless egr valve is slightly wedged up. if the egr is left alone an plugged in the car wont idle but has great throttle response,but it will only idle if the egr is wedged up but has crappy throttle response and runs like crap. egr wedged up is the only way it will idle. thanks for any suggestion guys
yeah I know it should hurt not help,but I ran out of ideas and thought what the hell and tried it. IAC,tps,map,O2 ,new gaskets from intake up,new vac lines from canister back,new fuel pump.As for my snap on scanner, sombody obviously liked it better than I and helped themselves to it and all my cards and K chips. So I dont have a clue as to what my readings are.SES is throwing codes but I know what those are caused from, and those aint the prob.
