need some help figuring out this advance timing light
Old May 18, 2003 | 10:58 AM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i think i got it worked out but want to make sure. instead of a trigger it has a dial that you turn which turns a wheel with numbers on it. i think you set the # of degrees you want BTDC in the middle of the display. then there's a switch for either 4C or 2C, this should be set to 4C for 4 cycle, right? then when you actually use it you want the timing line to show up at zero degrees on the tab when the dial on the gun is set to the amount of degrees advanced you want.
Old May 18, 2003 | 11:06 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Sounds right to me.
Old May 18, 2003 | 12:33 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Yes.
Old May 19, 2003 | 12:51 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Can't get nothing by you, can they?
That's exactly right.
The great thing about those guns is using them to check your timing curve AND total advance.
Of course if you're using EST, then it's arbitrary. My car (TBI) shows 44* total advance in "Park" while it's not under a load. That's a lot!! I seriously doubt it ever reaches that much under load ... although it's nice to know it CAN advance that much if necessary.
Azrael91966669
25
Jun 20, 2017 04:04 AM
Andrew6.688
Dec 13, 2015 10:59 AM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
Thirim
Aug 9, 2015 06:19 PM
