LT-5 swap for my '95 Fbird
Old Aug 1, 2000 | 03:57 PM
FBODY-ADDICT's Avatar
Big problem guys, I live in Dominican Republic and I got an '85 firebird with the 2.8l V6. I recently purchased a totaled ZR-1 vette (no damage whatsoever to the front end)
Now we got decent mechanics down here but I refuse tot totally trust any of them. I need help, Im not very handy with the wrench but I want to help install the LT-5 engine and the ZF-6 tranny on my bird. What do I need to buy to complete the swap? Please help me out, I know I got a pretty good deal going here and I want to make the most of the power in this engine.
Old Aug 1, 2000 | 04:09 PM
85ZZ4TPI's Avatar
You need to buy a crossmember for the t56 and I think you need a custom drive shaft. The donor car has everything else. You need to find somebody that can help you do it.
Old Aug 1, 2000 | 04:45 PM
88SS6SPEED's Avatar
Car: 88 Monte SS
Engine: Super-rammed L-98 383
Transmission: T-56 6-Speed
Axle/Gears: 8.5" G-BODY G-80 3.73
Hey bro. I like your attitude and passion. That is a very daunting project but it can be done. I must tell you that you will need alot of electrical experience. The best approach would be to leave everything hooked to the LT-5 and remove the complet wiring harness and vehicle harness from the Vette complete. It would be alot more simple to transplant it this way. First and foremost, you will need a ZR-1 HELMS manual and a F-BODY HELMS manual and thoroughly familiarize yourself with the common items of each entire system. For example, headlights are headlights, as far as their hook-up. I wish I could be there to help you, I love a good challenge. More than likely, you will have to heavily modify the saddle that the engine sits in since the LT-5 uses a much larger capacity oilpan. You will probably have to eliminate the pre-cats which is a good thing plus mandated TRUE DUAL exhaust. Email me and I will try and help you out with some of the particulars. Good luck.
88 Monte SS 355 TPI/LT-4 HOT CAM/AFR Hydra-rev/ T-56 6-Speed
Old Aug 1, 2000 | 05:14 PM
Tas's Avatar
Tas
cool deal. get some camaro books. some show the f-body prototype with the LT-5. they put big blocks in too to see how much power our cars can handle.
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
okfoz
Aug 21, 2015 07:38 AM
Hello, Michael
Aug 20, 2015 03:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
