Oil pressure problem
Old May 18, 2003 | 06:05 PM
BluthndrZ28's Avatar
Car: 1991 Z28
Engine: 5.7 TPI
Transmission: 700R4 w/2600 stall
The oil pressure is way high on my car & I was wondering if anyone has any insight as to why this may be happening. I noticed it last week when there was some oil spray over the right side valve cover & hoses. I took it in to the shop to have it looked at & the oil dipstick had a crack in it, at the weld. That was replaced & so was the oil pressure switch. I got the car back & it's still happening. I am getting readings of over 300 on startup & when driving it can go as high as 375. Although after the car warms up it seems to hover around 200. But once i hit the gas the pressure climbs right back up. I took another look under the hood & I think that the oil may possibly be coming back up thru the oil dipstick from the pressure being so high. Can anybody give me some possible idea what might cause this to happen & what kind of damage to the car this may do. Vehicle is '91 350TPI, oil used is amsoil syn, 10/40.
Old May 18, 2003 | 06:40 PM
ede's Avatar
ede
i don't know the metric stuff, but usually you aren't too high to cause problems. you may have a bad gauge or sender. to see what you really have screw a mechanical gauge in it.
Old May 18, 2003 | 07:24 PM
D's89IROCZ's Avatar
Car: 1989 IROC-Z
Engine: 5.7L EFI LTR setup
Transmission: T-5 World Class
but ....oil comeing up the dipstick is NOT normal .....I too have this problem ....and I have replaced the PCV valve . I am curious what this could be as well , because it got me kicked off the dam track today
.....it only happens when I am hard on the car
Old May 18, 2003 | 07:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
High oil pressure won't cause that problem.
Check your PCV system. Make sure the valve has vacuum, and that it sucks good if you put your finger over it with the engine running; and that the air supply into the othe rvalve cover is clear too. Sounds like the PCV hose may be blocked with crud buildup.
Old May 18, 2003 | 11:01 PM
Car: 1991 Z28
Engine: 5.7 TPI
So if my PCV system is functioning properly what would cause the pressure to go so high??
Old May 19, 2003 | 05:49 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Don't worry about the pressure. If it doesn't peg the gauge when it's hot, it's fine. You can't have too much oil pressure (well, at least as long as it doesn't blow up oil filters) just like you can't be too rich, or too good-looking, or too popular.
89GTAOz
May 16, 2020 09:31 AM
db057
Aug 22, 2015 08:17 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
