should i use the china wall gasket when sealing intake?
Old May 18, 2003 | 07:28 PM
Ukraine Train's Avatar
Car: '87 Camaro LT
Engine: 355 L98
i've never used the gasket that comes in the intake kit and just globbed on RTV but this time around when i did that i got a pretty decent oil leak going, i'm going to reseal it tuesday. should i use the rubber china wall gaskets or just RTV?
Old May 18, 2003 | 07:38 PM
BTS88IROC's Avatar
https://www.thirdgen.org/techbb2/sho...na+wall+gasket
I've always just used RTV and never had a problem.
Old May 19, 2003 | 08:22 AM
CraZ-28's Avatar
Car: 1991 Z-28
Engine: Can you say stroke?!?!
Transmission: 700-r4
I wouldn't. I have never seen one of the china wall gaskets actually seal properly. Now that I think about it, Felpro stopped putting them in the TPI gasket kits and included a bottle of RTV cause it works much better. Just make sure you've got a clean surface and the RTV will work much better than the gasket.
Old May 19, 2003 | 12:33 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Same thing with my Felpro "intake" gasket set for the 2.8 MFPI motor; a little squeeze tube of RTV instead of the gaskets.
1992 Trans Am
May 10, 2023 07:19 PM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
86White_T/A305
Aug 17, 2015 12:16 AM
