How do you install that AIRDAM?
Old May 20, 2003 | 10:10 AM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
I was just wondering how you install that spoiler that goes underneath the radiator because the car get's hot in my car and I need that spoiler so it doesnt get hot in my car even when the heat's off.
Old May 20, 2003 | 10:50 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Tinnerman nuts and sheet metal screws
Old May 20, 2003 | 04:11 PM
SilverSub122's Avatar
the two on the ends are hard to get, its easier to put those in if the radiator is out, but the rest all you do is get up under there with your nuts and bolts and fasten away, i dont remember if there is 4 or 6 bolt/screw holes, very simple tho, took me like 15 min and it dropped my engine temp 60*
Old May 20, 2003 | 09:15 PM
Vader's Avatar
Posted by RB83L69
Tinnerman nuts and sheet metal screws.
Doesn't Dirk get a little sensitive about that? And doesn't that limit you to TWO fasteners?
OH! "Tinnerman" nuts, not "Timmerman" nuts! Never mind....
Anyway, on my '86 the factory used the speed nuts and screws on the lower radiator support, and plasitc push rivets on the end pieces that attach to the outer ground effect and filers. The rubber aprons along side the radiator shell are also held by the plastic push rivets, except at the very bottom where the speed nuts and screws are installed żOdd, isn't it?
Old May 20, 2003 | 09:31 PM
dzimmerm's Avatar
Heat Off?
Warrior_91,
I was not sure what you meant by "even with the heat off".
It was an old trick that if your radiator was not up to snuff you could turn on the heat and the heater core would act as a mini radiator.
If it was a choice between frying your engine or having to drive with the heater on and the windows down it was better to run with the heater on full blast for better cooling.
dzimmerm
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
