Oil Pressure Sending Unit
Old May 20, 2003 | 09:55 PM
warrior_91's Avatar
Car: 86 T/A
Transmission: 700-R4 Auto
Hi, I was wondering whats wrong with my oil pressure gauge because when I turn my key to the "ON" position, it moves to the "0" mark. And it stays there when im driving. When I turn the car off it moves down to its original position. So the needle is moving, but staying at the "0" mark. I located my sending unit and unplugged it and when I turned my key to the on position, the needle jumped all the way up. So is my sending unit gone? If so, is it hard to install a new one becasause it's sorta hard to get to.
86 trans am
Old May 21, 2003 | 12:54 AM
25THRSS's Avatar
It is most likely your sending unit. I would definitely not drive my car with no oil pressure unless I knew for sure that was the problem. It's not that hard to do. Ive done it. Once you get under the car it's simple.
Old May 21, 2003 | 01:56 AM
Quick_Trans_Am's Avatar
Car: 1985 Pontiac Trans Am
Engine: 355 with stuffs.
Axle/Gears: 4.10 Posi
Originally posted by 25THRSS
.......Once you get under the car it's simple.
He's right. It's as simple as unscrewing the old one, and screwing in a new one. I put a little teflon tape on mine to keep it sealed.
Old May 21, 2003 | 02:25 AM
25THRSS's Avatar
I did that as well.
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
355sbcTPI
Aug 19, 2015 04:38 PM
