pictures of fuel lines on serpentine belt setups
I have recently converted to serp. setup from vbelt and don't know waht to do for the fuel lines. so can anybody and everybody please post pictures of how the lines are routed on these. any help would be great, thanks so so much :hail:
Josh
Josh
Car: 85 iroc & 81 sc
Engine: 357 tpi 350 4bbl
Transmission: 700r4/ richmond 4speed
Axle/Gears: 9 bolt 3.45/3.42 8.5"
I have the same problem rite now. I have heard though if you use the fuel lines from an 88 or newer tpi that they will work.
Thanks trickster that helps alot!!! the only question I have left is are the rubber lines interchangeable?? I have an 85 iroc I put the serp set on and I am just figuring out what I will need to get fuel up there before I place an order. Thanks
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Yes they are interchangeable between years. When you order the hoses, just ask for the pressure flex hose and the return flex hose. They will have 3/8" fittings on the pressure line and 5/16" fittings on the return line. Also don't forget that you will need o-rings for those lines or they will leak like a sieve.
well I finally got to the dealership today to order those fuel lines and they have been discontinued. Bad news!!! I emailed gmpartsdirect.com about 3 weeks ago and they havnt emailed me back yet. Any help???
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
