Steering Box
Old May 22, 2003 | 01:54 PM
Rage13's Avatar
Car: 89 Firebird
Steering Box
I've finaly found my PS leak, its the steering box... Now to find some info, what should one of these run? (money wise), is it worth getting one from the junk yard?, and i've heard some models had different turning ratios.. is this true? thanks in advance
Old May 22, 2003 | 08:49 PM
87WS6's Avatar
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Get one with a Z stamped on it. If you get it from a Z28 or a WS6 equipped car you should be ok. I got mine shipped from a user from Canada for about $80.
Old May 22, 2003 | 09:13 PM
Rage13's Avatar
Car: 89 Firebird
What dose the "Z" on it mean? And why do you say "If you get it from a Z28 or a WS6 equipped car you should be ok." If i get one from an RS will it not go back togeather easy?
Old May 22, 2003 | 09:15 PM
Dragons91RS's Avatar
Car: 91 Camaro RS
Engine: 305 LO3
Transmission: 700-R4
I just had to replace mine. it cost me $150 w/tax at O'Reilly.
I also came to find out the Z being stamped on it doesnt mean any thing. my old one had a z on it but my new one doesnt, and I know I got the correct one because it was looked up and ordered by the part # from the original one.
I would add if you think you are up to it you can rebuild your old one for $30.
Old May 23, 2003 | 02:35 PM
Rage13's Avatar
Car: 89 Firebird
Cool, thanks for the help guys
Old May 23, 2003 | 04:59 PM
Vader's Avatar
IIRC, the WS6 cars got a constant ratio steering box with a 12.7:1 ratio. I don't specifically know the "standard" box ratio, but it should be a variable ratio and from around 15.1:1 to 13.1:1 (variable depending on position from center).
83 Crossfire TA
Jan 3, 2016 01:26 PM
bubbaz28
Sep 18, 2015 02:09 PM
punkmaster98
Sep 8, 2015 09:45 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
