What cam for l98 heads?
Old May 24, 2003 | 01:19 AM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
I am getting a set of l98 heads for very very cheap. I plan on screw in studs and tougher springs. What cam would work well with the rest of my motor? Id like to get into the 13s at least with 3.42 gears.
I know this is possible but what cam should I run? LT4? ZZ4? aftermarket?
Old May 24, 2003 | 10:36 AM
Vader's Avatar
Do a search for the XR270HR cam. Of course, along with the screwed studs, you'll have to machine the spring seats for better springs and cut the guides for clearance and positive-type Teflon seals.
Since you're running a carb, you have a little more lattitude for your grind selection. That 270 would be a good starting point. If you don't mind a little more lope, a little less vacuum, and a little less streetability, you can experiment with more duration and overlap.
Frozer!!!
Jan 19, 2024 04:55 PM
lt500r55
Sep 1, 2021 01:30 PM
bamaboy0323
Sep 3, 2015 06:07 AM
midge54
Aug 29, 2015 09:51 PM
anesthes
Aug 8, 2015 09:37 PM
