Distributor is STUCK! How do I get it out?!?!?
Old Sep 11, 2000 | 10:26 AM
Conv389drv's Avatar
It's an LG4 engine. I'm trying to get the cylinder heads off so they can be rebuilt, but the distributor refuses to come out. (so I can't get the intake off) I've tried penetrating lube and hammering on the shaft, but no luck. There's about a millimeter of play left and right, but no play up or down. It's like it's fused to the block! I'm out of ideas!
Has anyone else had this problem? What do I do? Any help would be GREATLY appreciated!
Old Sep 11, 2000 | 10:35 AM
Jester's Avatar
I don't think there is really much trick to it..just need more brute force. try to pry it up with a 2x4 across the manifold, and then either a big crow bar or another 2x4 under the distributer.
Old Sep 11, 2000 | 10:47 AM
Paul Riccioli Jr's Avatar
Car: 89 IROC-Z
Engine: 383
This may sound simple, but did you remove the distributor hold down screw?
Riccioli Performance Motorworks
--RPM Racing--
Will be building 450 hp TPI 383 for my 89 IROC-Z this summer. Accel Super Ram, Edelbrock Intake and TB, Trickflow heads, MSD ignition, Hotchkis suspension, TPI Tech 700R4 tranny +many more goodies.
Old Sep 11, 2000 | 10:54 AM
Kevin G's Avatar
I came across this a couple times before. Usually the motor is pretty caked up with sludge, and it can be a real pain to get out. I would get some gum cutter and spray it down the dist. hole and let it sit about 20 minutes... then try to pry out the dist. Keep messsing with it, and eventually it will free up.
Old Sep 11, 2000 | 11:49 AM
Conv389drv's Avatar
Thanks guys. I've been trying the crud-cutting spray, but I've only been pulling on it by hand. I didn't really want to try and rip it out of there, but it looks like I'll have to risk it. (and yeah, I did remove the hold down bolt!)
Old Sep 11, 2000 | 12:00 PM
chevymike's Avatar
I had this problem on a friends V6 Camaro. It was the o-ring that had fused itself to the block. Just had to keep pulling and twisting to get it to come out. A real PITA. Good luck.
Mike Schwartz aka chevymike
'92 Z28, 5.7, Teal Hardtop
"Don't Outlaw High Performance Cars,
Outlaw Low Performance Drivers!"
Mike's Camaro Z28
Old Sep 11, 2000 | 12:14 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
well hopefully it wont come to this, but to get the distributer out of a friend of mines truck we had to use 3 2x4's that were about 4 feet long, with all of us jumpin up and down on the... needless to say we just bought a new ditributer
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Old Sep 11, 2000 | 03:40 PM
formula90's Avatar
Car: 1990 Formula
Engine: 5.7 liter
hey man i know what you are going through. this is what i did. 1st i got a can of wd40 and sprayed he **** out of the base of the distributer. let it sit for about 30 min. then i worked it back and forth even if it was just alittle bit and i tapped on it with the hammer (assuming you got the cap,rotor,module off) and put the hammer under there and pryed on it from 3 differnet angles. sprayed the **** out of it again. let it sit. tapped the distributer on top to loosen the crud it rusted to and repeated for 2 hours untill it budged. this will slowly bring the distributer out and finally it wll just pop right out. MAKE SURE YOU CLEAN THE SHAFT WITH SAND PAPER BEFORE YOU DROP IT BACK IN. SATURATE IT WITH WD40 AND WORK IT AROUND!! after you are done. you will basically be able to lift it with one finger out of there goodluck
I have experience...unfortunatly,its a result of bad judgement.
click below to check out MY FORMULA PAGE!
http://www.members.tripod.com/~Astralbaby/build/front.htm
or click below to email me
Astralbaby@webtv.net
Old Sep 11, 2000 | 07:29 PM
Conv389drv's Avatar
Yes! I finally got it. Thanks for the help everyone. I was out messing with it a little while ago. A neighbor I know came by and helped me out, and with the two of us twisting and prying it came out. After that, the intake and heads just came right off, fortunately (I had already taken everything else off). The bad news is that it looks like everythings pretty junked up and corroded in there from sitting so long, and also from the initial break-down. The cylinder walls have rust corrosion and crud in them, so, it looks like it's RIP for the ol' LG4.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Damon
Sep 26, 2015 04:29 PM
