Cam selection.
Old May 25, 2003 | 09:37 PM
86budgetSC's Avatar
Cam selection.
Hey there guys.
I bought an 86 camaro sport coupe about 2 years ago.Since then the motor and trans have been pulled.
I lost interest in the car.(not third gens just this car)
Now I have 2 old chevy trucks as toys.and a engineless camaro sitting behind my house a mom at the end of her witts with a crazy gearhead son.
I have a 79 350 4 bolt shortblock.I can put this 350 with spare parts.Except I need to buy a cam and lifters.
I will be using a torquer 2 intake and a edelbrock 600cfm carb.The convertor will be a summit built 1900 stall.I am going to a junkyard to find a good posi rear.Something around a 3:42 ratio.
What cam would you guys suggest for a 350 with a stock pistons,home ported 305 heads,torquer 2 intake,and a 600cfm carb.
I should be able to get the car running for under 200 bucks that is my plan.Any advice?
Old May 25, 2003 | 10:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
What heads? what gears?
Old May 26, 2003 | 09:27 AM
86budgetSC's Avatar
The rear gears right now are 2:73's.The rear is going to be changed to a posi unit with something like 3:42's.
What was the lowest gear ratio offered in third gens.And what is the RPO code.
The heads I am not sure of the casting #'s.I know there 305 heads off an 80's chevy truck.The only reason i am using them is for the small chambers to raise compression.
The car will have headers and 2.5 inch true duals.
I would go with better heads.Like I said though I am trying to do with with little spending as possible.
Thanks.
Old May 26, 2003 | 10:45 PM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Comp XE 262 or Crane PowerMax 266.
Old May 27, 2003 | 12:21 PM
86budgetSC's Avatar
The heads will likely be these.
casting # 3795896.I looked them up and they seem to be a 327 head with 60cc chambers.Are these any good?
Thanks.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
